warning removal changes
Ralf Corsepius ralf.corsepius at rtems.org
Fri Sep 8 09:09:49 UTC 2006
On Mon, 2006-09-04 at 08:43 -0500, Joel Sherrill wrote:
> >> Please update your tree and test.  If you see problems or
> >> have fixes for other warnings, please help.
> > I have built multilib kernels without bsps for arm i386 m68k mips
> > powerpc sh sparc tic4x targets. The get the following error with the
> > tic4x:
> > gmake[6]: Entering directory
> > `/local/tools/rtems/tools/packages/BUILD/rtems-4.7-tic4x-rtems4.7-4.6.99.3/build/tic4x-rtems4.7/cpukit/score/cpu/c4x'
> > if tic4x-rtems4.7-gcc --pipe -DHAVE_CONFIG_H   -I../../..
> > -I../../../../lib/include  -Wall -fasm -g -O2 -MT libscorecpu_a-cpu.o
> > -MD -MP -MF ".deps/libscorecpu_a-cpu.Tpo" -c -o libscorecpu_a-cpu.o
> > `test -f 'cpu.c' || echo
> > '../../../../../../rtems-4.6.99.3/cpukit/score/cpu/c4x/'`cpu.c; \
> > then mv -f ".deps/libscorecpu_a-cpu.Tpo" ".deps/libscorecpu_a-cpu.Po";
> > else rm -f ".deps/libscorecpu_a-cpu.Tpo"; exit 1; fi
> > In file included from ../../../../lib/include/rtems/score/cpu.h:28,
> >                  from ../../../../lib/include/rtems/system.h:184,
> >                  from
> > ../../../../../../rtems-4.6.99.3/cpukit/score/cpu/c4x/cpu.c:15:
> > ../../../../lib/include/rtems/score/types.h:36: error: syntax error
> > before "Priority_Bit_map_control"
> > ../../../../lib/include/rtems/score/types.h:36: warning: type defaults
> > to `int' in declaration of `Priority_Bit_map_control'
> > ../../../../lib/include/rtems/score/types.h:36: warning: data
> > definition has no type or storage class
> > gmake[6]: *** [libscorecpu_a-cpu.o] Error 1
> I haven't compiled the tic4x for a while and this looks like something
> that has been broken a while.
> uint16_t is NOT defined for the tic4x.
Right. The tic4x is special (The reason for me to keep the tic4x alive,
despite we all know the target to be more than dead):
The tic4x does NOT have [u]int16_t nor [u]int8_t, also the common
(bogus) assumptions on sizeof(char) == 8bit and sizeof(short) == 16bit
does not apply (on the tic4x all sizeof(any type) = 1 == 32bit).
The least-size types ([u]int_least<size>_t) however are available on the
tic4x, but beware: There is no guarantee of them being "minimal" nor of
them being optimal.
=> To make types portable to the tic4x you could use the least-size
types instead of fixed size types (That's what my RTEMS "hash"-patch to
newlib does (part of the current rtems newlib-patch)) or you could
conditionally define them.
Better, do not use any fixed size types, but ... due to current RTEMS
basic types design, this is hardly possible.
> Also I didn't have the tic4x tools installed and got this error.
> Something is wrong with the
> RPM DB on england:
> rpmdb: Program version 4.3 doesn't match environment version
> error: db4 error(-30974) from dbenv->open: DB_VERSION_MISMATCH: Database
> environment version mismatch
> error: cannot open Packages index using db3 -  (-30974)
> warning: cannot open Solve database in
> /usr/lib/rpmdb/i386-redhat-linux/redhat
> Any ideas?
The FC1 ... not unlikely bugs in its rpm implementation.
Ralf
