CRLF in CVS.
Mon Sep 11 11:12:32 UTC 2006
Chris Johns wrote:
> Hi Joel,
> Running the following on a CVS check out on a Linux box:
> [chrisjohns at england rtems-4.6.99.3]$ find . -exec file '{}' \; | grep
> CRLF
> ./contrib/mingw/README: ASCII English text, with CRLF line terminators
> ./contrib/mingw/AUTHORS: ASCII text, with CRLF line terminators
> ./contrib/mingw/rtems.ini: ASCII English text, with very long lines,
> ./contrib/mingw/COPYING: ASCII English text, with CRLF line terminators
> ./contrib/rtemsrpms/AUTHORS: ASCII text, with CRLF line terminators
> ./c/src/libchip/network/cs8900.h.bsp: ASCII C program text, with CRLF
> line terminators
> ./c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h: ASCII C program
> ./c/src/lib/libcpu/arm/s3c2400/include/s3c2400.h: ASCII English text,
> with CRLF, LF line terminators
> ./c/src/lib/libbsp/arm/gba/configure.ac: ASCII text, with CRLF line
> terminators
> ./c/src/lib/libbsp/arm/gba/README: ASCII English text, with CRLF line
> terminators
> ./c/src/lib/libbsp/arm/gp32/smc/smc.h: ASCII C program text, with
> ./c/src/lib/libbsp/powerpc/motorola_powerpc/times.mcp750: ASCII
> ./c/src/lib/libbsp/nios2/nios2_iss/start/crtnn.s: ASCII C program
> ./c/src/lib/libbsp/mips/hurricane/include/usc.h: ASCII C program text,
> ./testsuites/psxtests/psx04/psx04.scn: ASCII English text, with CRLF
> line terminators
>  $ find . -exec file '{}' \; | grep CRLF
> shows we have a number of files in CVS that have CRLF line endings.
> This breaks RTEMS if checked out on a Windows box. You get an extra
> set of CRLF's.
> Should I fix the source files ?
Yes.  Definitely.  They just slipped through.
> Regards
> Chris
