warning removal changes
Jerry Needell
jerry.needell at unh.edu
Mon Sep 11 17:22:40 UTC 2006
Joel - changing the unint32_t's to int32_t did the trick - the diff is
attached.
- Jerry
Joel Sherrill wrote:
> Jerry Needell wrote:
>> Joel - Just a heads-up while I keep debugging. Your "clean-up" broke
>> something in cpukit/libnetworking/netinet/in_cksum.c for the sparc
>> leon3 bsp.
>> When I tried to use the etherenet driver, it would hang in an
>> infinite loop in in_cksum.c. I mad a few quick changes to "undo" your
>> recent modifications and everything works fine. I'm trying to
>> understand why but I thought I'd let you know. Maybe the culprit will
>> leap out at you.
> There were two CVS commits. From 1.11 -> 1.12, the change was from an
> int cast to
> (intptr_t) around line 120. I doubt that broke it.
> From 1.10-> 1.11, I see that I changed two things. I added "L" onto
> the 65535's
> in ADDCARRY. I doubt that broke anything. But later in the file, I
> changed some ints
> to uint32_t's. Can you try changing those back to int32_t?
> cvs diff -r 1.10 -r 1.11 -u in_cksum.c
> to see the change. It almost has to be adding the unsigned.
> Let me know what works and post the diff. There wasn't much changed.
> --joel
>> - Jerry
>>> Hi,
>>> I have made numerous hopefully safe changes to eliminate
>>> warnings over the past few days. My goal was to significantly
>>> reduce the number of warnings on 16-bit targets but since
>>> all the code in question was target independent, it impacted
>>> other targets. I eliminated over 1000 warnings for h8300/multilib
>>> and about 1/2 for sparc/erc32.
>>> Please update your tree and test. If you see problems or
>>> have fixes for other warnings, please help.
>>> We are primarily dealing with 16/32 bit integer issues and
>>> pointer mangling that gcc doesn't like. I would like to
>>> be warning free. :)
>>> Thanks.
>>> --joel
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20060911/969039d4/attachment.bin>
