Source Paths in Sample Files
John Wood
jwood at scisol.com
Tue Sep 12 12:22:04 UTC 2006
Greetings all,
I am working on debugging a new BSP for a powerpc based board. The tool
I have is a windows based jtag emulator with a dedicated windows
debugger. I have found that my debugger does not locate the source
files. In the ELF file it appears that the source paths are referenced
to the build directory.
Is there an easy work around for getting my paths to be relative to my
example directory. I have built my image with both cygwin gcc and mingw
gcc. The only difference is that some of the includes from gcc libs are
absolute windows paths with the mingw build.
Thanks a lot,
John
