Source Paths in Sample Files
John Wood jwood at scisol.com
Tue Sep 12 18:07:27 UTC 2006
Thanks Chris.  It looks like using the absolute path and installing the
mingw32 environment as a shell to use the Windows paths as oppossed to
cygwin root may have done the trick.  I will have to wait until tonight
to load it into my debugger to see if there are any other issues but at
least it looks like I am on the right path.
John
-----Original Message-----
Sent: Tuesday, September 12, 2006 7:36 AM
To: John Wood
Cc: rtems-users at rtems.com
Subject: Re: Source Paths in Sample Files
John Wood wrote:
> Greetings all,
> I am working on debugging a new BSP for a powerpc based board.  The
> tool I have is a windows based jtag emulator with a dedicated windows
> debugger.  I have found that my debugger does not locate the source
> files.  In the ELF file it appears that the source paths are
> referenced to the build directory.
> Is there an easy work around for getting my paths to be relative to my
> example directory.  I have built my image with both cygwin gcc and
> mingw gcc.  The only difference is that some of the includes from gcc
> libs are absolute windows paths with the mingw build.
What happens if you use an absolute path to configure ?
See 'GDB Cannot Find My Source Files' in this page:
  http://www.rtems.org/wiki/index.php/DebuggingHints
Regards
