netdemo and the mvme2604
rtwas
rtwas at comcast.net
Mon Sep 25 19:43:32 UTC 2006
Hello,
I'm still have troubles with netdemo on the mvme2604. I worked with Till
on this almost exactly a year ago.
I was unable to spend any more time on it until now. I was using
rtems-4.6.2 at the time. I've upgraded to rtems-4.6.6
and tried again...
Basically I get a "Can't connect socket: Host is unreachable" error when
I type "t", which is supposed to cause it
to broadcast packets. Here's a dump of the console:
Copyright Motorola Inc. 1988 - 1997, All Rights Reserved
PPC1 Debugger/Diagnostics Release Version 3.5 - 01/30/98 RM01
COLD Start
Local Memory Found =02000000 (&33554432)
MPU Clock Speed =200Mhz
BUS Clock Speed =67Mhz
WARNING: Keyboard Not Connected
Reset Vector Location : ROM Bank B
Mezzanine Configuration: Single-MPU
Current 60X-Bus Master : MPU0
Idle MPU(s) : NONE
System Memory: 32MB, ECC Enabled (ECC-Memory Detected)
L2Cache: 256KB
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
Loading: mvme2604-0/boot
Client IP Address = 192.168.1.100
Server IP Address = 192.168.1.60
Gateway IP Address = 192.168.1.100
Subnet IP Address Mask = 255.255.255.0
Boot File Name = mvme2604-0/boot
Argument File Name =
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&263852, Bytes Loaded =&263852
Bytes/Second =&263852, Elapsed Time =1 Second(s)
Residual-Data Located at: $01F78000
Model: 000000000000000000000000000(e2)
Serial: MOT0325F15
Processor/Bus frequencies (Hz): 199921872/66636044
Time Base Divisor: 4000
Memory Size: 2000000
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
done
Now booting...
Welcome to rtems-4.6.6(PowerPC/PowerPC 604/mvme2307) on MVME 2600 with
MVME712M
OpenPIC found at C1000000.
pci : Interrupt routing not available for this bsp
OpenPIC Version 1.2 (2 CPUs and 16 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 1
OpenPIC timer frequency is 8329350 Hz
Please add code for PCI/ISA bridge init to
libbsp/powerpc/shared/irq/irq_init.c
If your card works correctly please add a test and set
known_cpi_isa_bridge to e
currentBoard = 15
Universe II PCI-VME bridge detected at 0xC1041000, IRQ 11
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
1: 0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
2: 0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
Universe Slave Ports:
0: 0xC0000000 0x01FE0000 0x80000000 A32, Pgm, Dat, Sup, Usr
Overriding main IRQ line PCI info with 5
tdec21140 : found device 'dc1', bus 0x00, dev 0x0E, func 0x00
dec2114x : unit 1 base address C1042100.
dec2114x : driver attached
dec2114x : driver tasks created
dec2114x : 08:00:3E:28:83:EA name 'dc1', io 11100, mem C1042100, int 10
dec2114x: Installing IRQ 10
Destination Gateway/Mask/Hw Flags Refs Use Expire Interface
127.0.0.1 127.0.0.1 UH 0 0 0 lo0
192.168.1.0 255.255.255.0 U 0 0 1 dc1
Create socket.
Create socket.
Bind socket.
Bind socket.
Listen.
Listen.
Accept.
Accept.
Create socket.
Bind socket.
Connect socket.
Here's a dump of the PPCBug variables:
PPC1-Bug>env
Bug or System environment [B/S] = B?
Field Service Menu Enable [Y/N] = N?
Remote Start Method Switch [G/M/B/N] = B?
Probe System for Supported I/O Controllers [Y/N] = Y?
Auto-Initialize of NVRAM Header Enable [Y/N] = Y?
Network PReP-Boot Mode Enable [Y/N] = Y?
Negate VMEbus SYSFAIL* Always [Y/N] = N?
SCSI Bus Reset on Debugger Startup [Y/N] = N?
Primary SCSI Bus Negotiations Type [A/S/N] = A?
Primary SCSI Data Bus Width [W/N] = N?
Secondary SCSI Identifier = "07"?
NVRAM Bootlist (GEV.fw-boot-path) Boot Enable [Y/N] = N?
NVRAM Bootlist (GEV.fw-boot-path) Boot at power-up only [Y/N] = N?
NVRAM Bootlist (GEV.fw-boot-path) Boot Abort Delay = 5?
Auto Boot Enable [Y/N] = N?
Auto Boot at power-up only [Y/N] = N?
Auto Boot Scan Enable [Y/N] = Y?
Auto Boot Scan Device Type List = FDISK/CDROM/TAPE/HDISK/?
Auto Boot Controller LUN = 00?
Auto Boot Device LUN = 00?
Auto Boot Partition Number = 00?
Auto Boot Abort Delay = 7?
Auto Boot Default String [NULL for an empty string] = ?
ROM Boot Enable [Y/N] = N?
ROM Boot at power-up only [Y/N] = Y?
ROM Boot Enable search of VMEbus [Y/N] = N?
ROM Boot Abort Delay = 5?
ROM Boot Direct Starting Address = FFF00000?
ROM Boot Direct Ending Address = FFFFFFFC?
Network Auto Boot Enable [Y/N] = N?
Network Auto Boot at power-up only [Y/N] = N?
Network Auto Boot Controller LUN = 00?
Network Auto Boot Device LUN = 00?
Network Auto Boot Abort Delay = 5?
Network Auto Boot Configuration Parameters Offset (NVRAM) = 00001000?
Memory Size Enable [Y/N] = Y?
Memory Size Starting Address = 00000000?
Memory Size Ending Address = 02000000?
DRAM Speed in NANO Seconds = 60?
ROM First Access Length (0 - 31) = 10?
ROM Next Access Length (0 - 15) = 0?
DRAM Parity Enable [On-Detection/Always/Never - O/A/N] = O?
L2Cache Parity Enable [On-Detection/Always/Never - O/A/N] = O?
PCI Interrupts Route Control Registers (PIRQ0/1/2/3) = 0A0B0E0F?
Serial Startup Code Master Enable [Y/N] = N?
Serial Startup Code LF Enable [Y/N] = N?
VME3PCI Master Master Enable [Y/N] = Y?
PCI Slave Image 0 Control = 00000000?
PCI Slave Image 0 Base Address Register = 00000000?
PCI Slave Image 0 Bound Address Register = 00000000?
PCI Slave Image 0 Translation Offset = 00000000?
PCI Slave Image 1 Control = 00000000?
PCI Slave Image 1 Base Address Register = 01000000?
PCI Slave Image 1 Bound Address Register = 20000000?
PCI Slave Image 1 Translation Offset = 00000000?
PCI Slave Image 2 Control = 00000000?
PCI Slave Image 2 Base Address Register = 20000000?
PCI Slave Image 2 Bound Address Register = 22000000?
PCI Slave Image 2 Translation Offset = D0000000?
PCI Slave Image 3 Control = 00000000?
PCI Slave Image 3 Base Address Register = 2FFF0000?
PCI Slave Image 3 Bound Address Register = 30000000?
PCI Slave Image 3 Translation Offset = D0000000?
VMEbus Slave Image 0 Control = E0F20000?
VMEbus Slave Image 0 Base Address Register = 00000000?
VMEbus Slave Image 0 Bound Address Register = 02000000?
VMEbus Slave Image 0 Translation Offset = 80000000?
VMEbus Slave Image 1 Control = 00000000?
VMEbus Slave Image 1 Base Address Register = 00000000?
VMEbus Slave Image 1 Bound Address Register = 00000000?
VMEbus Slave Image 1 Translation Offset = 00000000?
VMEbus Slave Image 2 Control = 00000000?
VMEbus Slave Image 2 Base Address Register = 00000000?
VMEbus Slave Image 2 Bound Address Register = 00000000?
VMEbus Slave Image 2 Translation Offset = 00000000?
VMEbus Slave Image 3 Control = 00000000?
VMEbus Slave Image 3 Base Address Register = 00000000?
VMEbus Slave Image 3 Bound Address Register = 00000000?
VMEbus Slave Image 3 Translation Offset = 00000000?
PCI Miscellaneous Register = 10000000?
Special PCI Slave Image Register = 00000000?
Master Control Register = 80C00000?
Miscellaneous Control Register = 52060000?
User AM Codes = 00000000?
Here's a dump of an niot session:
PPC1-Bug>niot
Controller LUN =00?
Device LUN =00?
Node Control Memory Address =01F9E000?
Client IP Address =192.168.1.100?
Server IP Address =192.168.1.60?
Subnet IP Address Mask =255.255.255.0?
Broadcast IP Address =192.168.1.255?
Gateway IP Address =192.168.1.100?
Boot File Name ("NULL" for None) =mvme2604-0/boot?
Argument File Name ("NULL" for None) =?
Boot File Load Address =001F0000?
Boot File Execution Address =001F0000?
Boot File Execution Delay =00000000?
Boot File Length =00000000?
Boot File Byte Offset =00000000?
BOOTP/RARP Request Retry =00?
TFTP/ARP Request Retry =00?
Trace Character Buffer Address =00000000?
BOOTP/RARP Request Control: Always/When-Needed (A/W)=W?
BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
Here's a dump of networkconfig.h:
* Network configuration
* EDIT THIS FILE TO REFLECT YOUR NETWORK CONFIGURATION *
* BEFORE RUNNING ANY RTEMS PROGRAMS WHICH USE THE NETWORK! *
* $Id: networkconfig.h,v 1.8 2001/08/31 18:11:43 joel Exp $
#ifndef _RTEMS_NETWORKCONFIG_H_
#define _RTEMS_NETWORKCONFIG_H_
* The following will normally be set by the BSP if it supports
* a single network device driver. In the event, it supports
* multiple network device drivers, then the user's default
* network device driver will have to be selected by a BSP
* specific mechanism.
/* static char ethernet_address[6] = { 0x08, 0x00, 0x3e, 0x12, 0x28,
0xb1 }; */
//static char ethernet_address[6] = { 0x00, 0x80, 0x7F, 0x22, 0x61, 0x77 };
extern int rtems_dec21140_driver_attach();
extern int rtems_bsdnet_loopattach();
#define RTEMS_BSP_NETWORK_DRIVER_NAME "dc1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_dec21140_driver_attach
* Loopback interface
static struct rtems_bsdnet_ifconfig loopback_config = {
"lo0", /* name */
rtems_bsdnet_loopattach, /* attach function */
NULL, /* link to next interface */
"127.0.0.1", /* IP address */
"255.0.0.0", /* IP net mask */
* Default network interface
static struct rtems_bsdnet_ifconfig netdriver_config = {
"dc1", // name */
rtems_dec21140_driver_attach, // attach function */
&loopback_config, // No more interfaces */
"192.168.1.100", // IP address */
"255.255.255.0", // IP net mask */
NULL, // Ethernet hardware address */
0 // Use default driver parameters */
struct rtems_bsdnet_config rtems_bsdnet_config = {
&netdriver_config,
NULL,
0, /* Default network task priority */
0, /* Default mbuf capacity */
0, /* Default mbuf cluster capacity */
"rtems_host", /* Host name */
"nodomain.com", /* Domain name */
0, /* Gateway */
0, /* Log host */
{0}, /* Name server(s) */
{0}, /* NTP server(s) */
* A real example -- DO NOT USE THIS YOURSELF!!!
#if 0
"dy4", /* Host name */
"NOT_oarcorp.com", /* Domain name */
"192.168.1.2", /* Gateway */
"192.168.1.2", /* Log host */
{"192.168.1.2" }, /* Name server(s) */
{"192.168.1.2" }, /* NTP server(s) */
#endif
* For TFTP test application
#if (defined (RTEMS_USE_BOOTP))
#define RTEMS_TFTP_TEST_HOST_NAME "BOOTP_HOST"
#define RTEMS_TFTP_TEST_FILE_NAME "BOOTP_FILE"
#else
#define RTEMS_TFTP_TEST_HOST_NAME "XXX.YYY.ZZZ.XYZ"
#define RTEMS_TFTP_TEST_FILE_NAME "tftptest"
#endif
#endif /* _RTEMS_NETWORKCONFIG_H_ */
rtems-4.6.6 was configured with:
<../rtems-4.6.5/configure --target=powerpc-rtems --enable-rtemsbsp=mvme2307
Thanks.
Robert W.
