warning removal changes
Chris Johns
chrisj at rtems.org
Tue Sep 5 05:51:03 UTC 2006
Joel Sherrill wrote:
> Also I didn't have the tic4x tools installed and got this error.
> Something is wrong with the
> RPM DB on england:
> rpmdb: Program version 4.3 doesn't match environment version
> error: db4 error(-30974) from dbenv->open: DB_VERSION_MISMATCH: Database
> environment version mismatch
> error: cannot open Packages index using db3 - (-30974)
> warning: cannot open Solve database in
> /usr/lib/rpmdb/i386-redhat-linux/redhat
> Any ideas?
No idea. Are you using one of the older 7.? versions ?
>> I have errors with the bsps on the m68k target. I do not know the
>> status of the other bsps.
> I have fixed this.
> It made me wonder if we had a .h file "rtems/bspkit.h" and let it set
> the baseline API for a BSP
> wouldn't be a good idea. Even if now it had conditional compilation for
> variations, it would
> capture the issues like the pci did. Then eventually it would be
> included by EVERY bsp and
> could be used by libchip and other places as the "guaranteed cross-BSP API"
So would these interfaces be better declared in libchip or higher and
used by the bsp or where-ever ?
I also wonder if the header files be functionally based rather than a
single file ?
Regards
