Dynamic Libraries
Till Straumann strauman at slac.stanford.edu
Tue Sep 5 15:25:07 UTC 2006
Marek Prochazka wrote:
>Hi,
>cexp seems quite interesting, but I do not see any guide how to use the
>dynamic loader without the interpreter. I want to run my code and then
>at some point use cexpModuleLoad etc. To do that I need some basic cexp
>API documentation.
Consult the header 'cexp.h'. You can call cexpModuleLoad() etc. from
ordinary C-code.
>Thanks,
>Marek
>>Check out cexp:
>>http://www.slac.stanford.edu/comp/unix/package/rtems/src/ssrlA
>>pps/cexp/README
>>The code can be found here:
>>ftp://www.rtems.org/pub/rtems/4.6.99.3/contrib/cexp
You should always download from the cexp home page (i.e., the stanford
site) to make sure you got the latest version. rtems.org usually lags a bit
behind...
HTH
-- Till
>>Regards
>>Chris
