Dynamic Libraries
Marek Prochazka
Marek.Prochazka at scisys.co.uk
Mon Sep 11 09:36:26 UTC 2006
Till,
I'm having a problem linking in the file generated by xsyms. Here is
what I do. I have a Loader application and then a TestApp which I want
to load at runtime.
test: Loader.o TestAoo.o
@echo --------- Linking Loader application - first pass
$(CC) $(CFLAGS) Loader.o $(CEXP_LDFLAGS) $(CEXP_LIBS) $(LDFLAGS)
$(LDLIBS) -o Loader
@echo --------- Generating SYSTEM symbol table
$(XSYMS) -C Loader Symbols.c
@echo --------- Compiling SYSTEM symbol table
$(CC) $(CFLAGS) -c -fomit-frame-pointer -fasm -O Symbols.c
@echo --------- Linking Loader application - second pass
$(CC) $(CFLAGS) Symbols.o Loader.o $(CEXP_LDFLAGS) $(CEXP_LIBS)
$(LDFLAGS) $(LDLIBS) -o Loader
I successfully generate system table from the Loader executable in
Symbols.c, but then when I'm linking Symbols.o I got the following error
Symbols.o(.data+0x4): undefined reference to `__cexp__dummy_alias_0'
Symbols.o(.data+0x1c): undefined reference to `__cexp__dummy_alias_1'
Symbols.o(.data+0x34): undefined reference to `__cexp__dummy_alias_2'
Symbols.o(.data+0x1fc): undefined reference to `__cexp__dummy_alias_21'
Symbols.o(.data+0x214): undefined reference to `__cexp__dummy_alias_22'
collect2: ld returned 1 exit status
It is true that Symbols.c contains for every "dummy alias" an asm line,
but not for aliases 0-22:
#include <cexpsyms.h>
extern int __cexp__dummy_alias_0;
extern int __cexp__dummy_alias_1;
extern int __cexp__dummy_alias_2;
extern int __cexp__dummy_alias_20;
extern int __cexp__dummy_alias_21;
extern int __cexp__dummy_alias_22;
extern int __cexp__dummy_alias_1083;
asm(".set __cexp__dummy_alias_1083,_bfd_elf_sizeof_headers\n");
extern int __cexp__dummy_alias_1084;
asm(".set __cexp__dummy_alias_1084,del_GetLine\n");
extern int __cexp__dummy_alias_1085;
Any hints, please?
Thanks,
Marek
> -----Original Message-----
> From: Till Straumann [mailto:strauman at slac.stanford.edu]
> Sent: 05 September 2006 18:28
> To: Marek Prochazka
> Cc: Chris Johns; rtems-users at rtems.com
> Subject: Re: Dynamic Libraries
> Marek Prochazka wrote:
> > Hi Till,
> > thanks for your quick response. So, after I call cexpInit()
> This initializes the library but before you can use
> 'cexpModuleLoad' you
> must have the application's symbol table loaded (aka 'system
> symbol table').
> You can either (see README)
> a) compile this in: E.g., using the 'xsyms' or 'ldep' tool
> you create a
> symbol table '.c' file which is then compiled and linked with the
> application.
> b) use 'cexpModuleLoad()' to load symbols from an object (ELF) file.
> If no system symbol table is present when cexpModuleLoad is
> executed then cexpModuleLoad assumes it should just use
> the symbol
> table of the argument file to construct the system symbol table.
> > and load a
> > module using cexpModuleLoad(),
> yes
> > I can look for a function symbol using
> > cexpSymLookup().
> yes
> > This way I get CexpSym. Given that the symbol was a
> > function, is the way to call this function to consider
> > CexpSymRec_.value.tv as TFuncP (or TDFuncP?),
> you should use cexpSymValue(CexpSym) to obtain the value
> of the symbol (function or variable address). You then cast
> the void* returned by cexpSymValue() to the correct type
> (up to you to know what type that is).
> > cast this value to a
> > function pointer and call it?
> Yes.
> HTH
> -- Till
> > Or is there a cext_ function which I
> > missed to be used?
> > Many thanks,
> > Marek
> >> Sent: 05 September 2006 16:25
> >> To: Marek Prochazka
> >>> Hi,
> >>> cexp seems quite interesting, but I do not see any guide how
> >> to use the
> >>> dynamic loader without the interpreter. I want to run my
> >> code and then
> >>> at some point use cexpModuleLoad etc. To do that I need some
> >> basic cexp
> >>> API documentation.
> >> Consult the header 'cexp.h'. You can call cexpModuleLoad()
> etc. from
> >> ordinary C-code.
> >>> Thanks,
> >>> Marek
> >>>> Check out cexp:
> >>>> http://www.slac.stanford.edu/comp/unix/package/rtems/src/ssrlA
> >>>> pps/cexp/README
> >>>> The code can be found here:
> >>>> ftp://www.rtems.org/pub/rtems/4.6.99.3/contrib/cexp
> >> You should always download from the cexp home page (i.e.,
> the stanford
> >> site) to make sure you got the latest version. rtems.org
> >> usually lags a bit
> >> behind...
> >> HTH
> >> -- Till
> >>>> Regards
> >>>> Chris
