GDB macros
Luca Germano
lucagermano at hotmail.com
Wed Sep 13 07:47:41 UTC 2006
Hi, thanks for your help.
I'm using the GDB macros version of the rtems wiki. I'm using RTEMS on Leon3
CPU.
I find the problems.
When a macro refers to an RTEMS global variables is necessary to cast the
variables to the primitive type of the variable to be able to access its
fields. Doing the cast the macros work fine. For examples in the
rtems_classic_tasks macros I can't use directly _RTEMS_tasks_Information but
I must do
set $prova = (Objects_Information)_RTEMS_tasks_Information
rtems_helper_show_task $prova $arg0
instead of
rtems_helper_show_task _RTEMS_tasks_Information $arg0
In some macro there are some pointer conversion cast for example
(Thread_Control_struct *)
Also this instraction doesn't work. I must use
(Thread_Control *)
Now I must correct all the macros.
The ultimate thing to set is the macro rtems_task_backtrack that is HW
dependent. Someone know the field of the structure Register of the RTEMS
context switch to use for Leon3?
Best Regards
Luca Germano
>From: Paul Whitfield <paulw at omnitronics.com.au>
>To: Luca Germano <lucagermano at hotmail.com>
>CC: leonp at plris.com, rtems-users at rtems.com
>Subject: Re: GDB macros
>Date: Wed, 13 Sep 2006 08:54:54 +0800
>Luca Germano wrote:
>>I put a breakpoint in the program. After program execution stop on the
>>breakpoint I execute the macro.
>>Luca
>>>From: leonp at plris.com
>>>To: rtems-users at rtems.com
>>>Date: Tue, 12 Sep 2006 11:41:08 +0300
>>>On Tuesday, 12 ×September 2006 11:37, Luca Germano wrote:
>>> > Thanks for the help.
>>> > I try to use the rtems_classic_tasks macro but gdb give me the
>>>following
>>> > reply
>>> > Attempt to extract a component of a value that is not a structure.
>>> > # | Name | ID | Pri | Ticks | State
>>> > How can I solve this problem?
>>>Is the program running? I mean have you stopped it in the middle of the
>>>execution and them executed the macro?
>Hi Luca,
>Which version of the Macros are you using?
>Make sure you are using the latest ones from the rtems wiki.
>Also I have found in the past you need to use the command line
>version of gdb to debug the macros, if you use a GUI/IDE interface
>such as insight or emacs it hides error messages from you which
>makes it difficult to debug the problem(s).
>Regards
>Paul
>The information in this e-mail is intended for the addressee only.
>Unauthorised use, copying, disclosure or distribution by anyone else
>is prohibited. Please let us know immediately if you receive this
>e-mail in error. Thank you.
