Dynamic Libraries
Marek Prochazka
Marek.Prochazka at scisys.co.uk
Thu Sep 14 15:50:11 UTC 2006
Thanks for this hint, I'll look at the binutils discussion on this
issue.
Marek
> AFAIK this is an ld issue not specifically Cexp. I saw this
> message about
> this error message on an old thread on the binutils list
> (typed in so I
> hope
> the URL is right):
> http://sourceware.org/ml/binutils/2003-04/msg00540.html
> Maybe you can tell from that discussion what is going on with
> this linker
> script. I don't think this is as much SPARC specific as an
> odd side-effect
> of your test case and linker script.
> --joel
> > Thanks.
> > Best regards,
> > Marek Prochazka
> >> -----Original Message-----
> >> From: Marek Prochazka [mailto:Marek.Prochazka at scisys.co.uk]
> >> Sent: 12 September 2006 17:18
> >> To: Till Straumann
> >> Cc: rtems-users at rtems.com
> >> Subject: RE: Dynamic Libraries
> >> Hi,
> >> I have successfully linked a Cexp "loader" application on
> >> Linux and was
> >> able to load modules at runtime. Quite good stuff!
> >> When I am trying to do the same for sparc-rtems target, I get the
> >> following message when linking:
> >> /opt/rtems-4.6/lib/gcc-lib/sparc-rtems/3.2.3/../../../../sparc
> >> -rtems/bin
> >> /ld: ADDR forward reference of section .text
> >> My link_helper file looks like this:
> >> __cexp__dummy_alias_0 = ADDR( .text ) ;
> >> __cexp__dummy_alias_1 = ADDR( .data ) ;
> >> __cexp__dummy_alias_2 = ADDR( .bss ) ;
> >> __cexp__dummy_alias_3 = ADDR( .jcr ) ;
> >> Corresponding part of mysymbtab.c is
> >> static CexpSymRec systemSymbols[] = {
> >> .name =".text",
> >> .value.ptv =(void*)&__cexp__dummy_alias_0,
> >> .value.type =TVoid,
> >> .size =0,
> >> .flags =0|CEXP_SYMFLG_SECT,
> >> .name =".data",
> >> .value.ptv =(void*)&__cexp__dummy_alias_1,
> >> .value.type =TVoid,
> >> .size =0,
> >> .name =".bss",
> >> .value.ptv =(void*)&__cexp__dummy_alias_2,
> >> .value.type =TVoid,
> >> .size =0,
> >> .name =".jcr",
> >> .value.ptv =(void*)&__cexp__dummy_alias_3,
> >> .value.type =TVoid,
> >> .size =0,
> >> I have built libcexp for sparc-rtems and xsyms on Linux for
> >> sparc-rtems
> >> target. When I tried to build xsyms on top of libelf (--disable-bfd
> >> --disable-cexp) then the mysymtab.c file generated by xsyms
> >> is actually
> >> a binary file - so I do not know how use it.
> >> Any hints related to this?
> >> Many thanks,
> >> Marek
> >>> Sent: 12 September 2006 09:28
> >>> To: Till Straumann
> >>> Hi,
> >>> thanks, this helped me to link it! BTW my version of the
> >> README file,
> >>> which comes from Cexp 1.5 sources downloaded from the Cexp
> >> home page,
> >>> does not mention the trick with "> link_helper" in points
> 2) and 4).
> >>> Regards,
> >>> Marek
> >>>> Allan is correct. RTMF (see step 4), please [from the README]:
> >>>> > 1) compile and link all sources, libraries etc.; build an
> >>>> executable
> >>>> > 2) xsyms -C executable mysymtab.c > link_helper
> >>>> > 3) compile mysymtab.c (set -I to Cexp source directory, since
> >>>> > cexpsyms.h is included)
> >>>> > 4) link application again, but this time add
> >> 'mysymtab.c' to the
> >>>> > list of sources and 'link_helper' to the list of files to
> >>>> > be linked.
> >>>> > NOTE: Step 1) linking succeeds without a symtab.o
> >>> because there's
> >>>> > a weak NULL-ptr alias for the builtin symtab.
> >>>> HTH
> >>>> -- Till
