GDB macros
Luca Germano
lucagermano at hotmail.com
Fri Sep 15 07:07:53 UTC 2006
Ok I'll update the code of gdb macros in the wiki.
I attach the code also to this post
Best Regards
Luca
Code for gdb macros for Rtems on Leon3 CPU
# GDB macros for analyzing RTEMS threads
# 7 August 2006 - Joel:
# + Use Thread_Control_struct not Thread_Control to make gdb happy.
# Who knows why this makes gdb happier?
# 10 July 2006 - Joel:
# + Renamed all methods to start with rtems_ if public and rtems_helper_
# if private
# + Merged code to dump timer delta chain
# + Added code to dump Classic Semaphores, Message Queues, and Regions
# + Added support code to dump SuperCore Mutexes, Semaphores,
# Message Queues, Thread Queues, and Heaps
# TODO:
# + rtems_task_backtrack is CPU specific. How to fix?
# + Need to detect when POSIX and ITRON are not configured so
# a nice message is printed when those commands are used
# + Add support for Classic API
# - Periods
# - Timers
# - Partitions
# + Add support for POSIX API
# - Message Queues
# Commands implemented:
# rtems_task_backtrack TCB
# rtems_print_name name
# rtems_internal_task index
# rtems_internal_tasks
# rtems_classic_tasks
# rtems_classic_task index
# rtems_classic_semaphore index
# rtems_classic_semaphores
# rtems_classic_message_queue index
# rtems_classic_message_queues
# rtems_classic_region index
# rtems_classic_regions
# rtems_posix_thread index
# rtems_posix_threads
# rtems_posix_semaphore index
# rtems_posix_semaphores
# rtems_posix_mutex index
# rtems_posix_mutexes
# rtems_tasks
# rtems_internal_ticks_chain
# rtems_internal_seconds_chain
# rtems_malloc_walk
# rtems_workspace_walk
# rtems_tod
# rtems_check_state
######## Public Helper Macros
# ABSTRACT
# Print backtrace of an RTEMS task
# ARGUMENTS:
# arg0 = pointer to the Thread_Control_struct of the task.
define rtems_task_backtrack
# Uncomment the following line for PowerPC support
# set $stkp = $arg0->Registers.gpr1
# Uncomment the following line for Coldfire support
# set $stkp = $arg0->Registers.a6
# set $stkp = *(void**)$stkp
# vedere struttura Context_Control
set $stkp = $arg0->Registers.i6_fp
while $stkp != 0
info line **((void**)$stkp+1)
end
end
document rtems_task_backtrack
Usage: rtems_task_backtrack TCB
Displays a stack trace for the specific task
end
# rtems_print_name
# ABSTRACT
# ARGUMENTS:
# arg0 = object name -- 32 bit format
define rtems_print_name
set $name = $arg0
set $n0 = (char) ($name >> 24)
if $n0 < ' ' || $n0 > 'z'
set $n0=' '
end
printf "%c",$n0
set $n1 = (char) (0xff & ($name >> 16))
if $n1 < ' ' || $n1 > 'z'
set $n1=' '
end
printf "%c",$n1
set $n2 = (char) (0xff & ($name >> 8))
if $n2 < ' ' || $n2 > 'z'
set $n2=' '
end
printf "%c",$n2
set $n3 = (char) (0xff & $name)
if $n3 < ' ' || $n3 > 'z'
set $n3=' '
end
printf "%c | ",$n3
end
document rtems_print_name
Usage: rtems_print_name name
Attempt to print the Classic API style name in ASCII
end
######## Helper Macros - Use Only From Other Macros
# rtems_helper_task_dump
# ABSTRACT
# Print information about an RTEMS task
# ARGUMENTS
# arg0 = Task index in the corresponding _Information table.
# arg1 = pointer to the Thread_Control_struct of the task.
# arg2 = 1 for verbose output, 0 otherwise
define rtems_helper_task_dump
set $d1t_num = $arg0
set $pt = $arg1
set $d1t_verbose = $arg2
printf "%2d | ", $d1t_num
set $id = $pt->Object.id
set $name = (unsigned int)$pt->Object.name
rtems_print_name $name
printf "%08x | ",$id
set $state = $pt->current_state
set $pri = $pt->current_priority
printf "%3d | ",$pri
set $ticks = $pt->ticks_executed
printf "%8d | ", $ticks
if $state == 0
printf "READY"
end
if $state & 1
printf "DORM "
end
if $state & 2
printf "SUSP "
end
if $state & 4
printf "TRANS "
end
if $state & 8
printf "DELAY "
end
if $state & 0x10
printf "Wtime "
end
if $state & 0x20
printf "Wbuf "
end
if $state & 0x40
printf "Wseg "
end
if $state & 0x80
printf "Wmsg "
end
if $state & 0x100
printf "Wevnt "
end
if $state & 0x200
printf "Wsem "
end
if $state & 0x400
printf "Wmutex 0x%8x", $pt->Wait.id
end
if $state & 0x800
printf "Wcvar "
end
if $state & 0x1000
printf "Wjatx "
end
if $state & 0x2000
printf "Wrpc "
end
if $state & 0x4000
printf "Wrate "
end
if $state & 0x8000
printf "Wsig "
end
if $state & 0x10000
printf "Wisig "
end
printf "\n"
# printf "\
#---+------+----------+-----+----------+------------------------------\n"
if $d1t_verbose
printf "\
BACKTRACE\n\
13:37, 11 Jul 2006 (CDT)[[User:JoelSherrill|Dr. Joel]] 13:37, 11 Jul 2006
(CDT)\n"
rtems_task_backtrack $pt
end
end
# Internal Helper Do Not Document
# rtems_helper_task_header
# ABSTRACT
# Print the header of the task list table
define rtems_helper_task_header
printf "\
=====================================================================\n"
printf "\
# | Name | ID | Pri | Ticks | State\n"
printf "\
end
# rtems_helper_show_task
# ABSTRACT
# Support routine for verbose listing of a single task
# ARGUMENTS
# arg0 = _Information table.
# arg1 = index.
define rtems_helper_show_task
set $pt = (Thread_Control *)$arg0.local_table[$arg1]
rtems_helper_task_dump $arg1 $pt 1
end
# rtems_helper_show_tasks
# ABSTRACT
# Support routine for verbose listing of all tasks of a given class
# ARGUMENTS
# arg0 = _Information table for the class (internal, classic, POSIX
etc.).
define rtems_helper_show_tasks
set $index = 1
while $index <= $arg0.maximum
set $pt = (Thread_Control *)$arg0.local_table[$index]
if $pt != 0
rtems_helper_task_dump $index $pt 0
end
set $index = $index + 1
end
end
######## Helper Macros For SuperCore - Use Only From Other Macros
# rtems_helper_score_threadq
# ABSTRACT
# Verbosely list a single SuperCore thread queue
# ARGUMENTS
# arg0 = pointer to the thread queue
define rtems_helper_score_threadq
set $tq = $arg0
set $THREAD_QUEUE_DISCIPLINE_FIFO = 0
set $THREAD_QUEUE_DISCIPLINE_PRIORITY = 1
if $tq->discipline == $THREAD_QUEUE_DISCIPLINE_FIFO
printf " FIFO - "
set $limit = 1
end
if $tq->discipline == $THREAD_QUEUE_DISCIPLINE_PRIORITY
printf " PRIO - "
set $limit = 3
end
# now walk them
set $count = 0
set $pri_index = 0
set $queues = &$tq->Queues
while $pri_index < $limit
set $chain = &$queues.Priority[$pri_index]
set $ptail = &$chain->permanent_null
set $next = $chain->first
while $next != $ptail
set $t = (Thread_Control *)$next
printf "0x%08x@%d ", $t->Object.id, $t->current_priority
set $next = $next->next
set $count = $count + 1
end
set $pri_index = $pri_index + 1
end
if $count == 0
printf "%s", "No waiting threads"
end
end
# rtems_helper_score_heap
# ABSTRACT
# Verbosely list contents of a SuperCore Heap
# ARGUMENTS
# arg0 = pointer to heap
define rtems_helper_score_heap
set $heap = $arg0
set $heapstart = $heap->start
set $currentblock = $heapstart
set $used = 0
set $numused = 0
set $free = 0
set $numfree = 0
while $currentblock->front_flag != 1
if $currentblock->front_flag & 1
if $arg0 != 0
printf "USED: %p %d\n", $currentblock, $currentblock->front_flag & ~1
else
printf "*"
end
set $used = $used + $currentblock->front_flag & ~1
set $numused = $numused + 1
else
if $arg0 != 0
printf "FREE: %p %d\n", $currentblock, $currentblock->front_flag & ~1
else
printf "."
end
set $free = $free + $currentblock->front_flag & ~1
set $numfree = $numfree + 1
end
set $currentblock = \
(Heap_Block *)((char *)$currentblock +
($currentblock->front_flag&~1))
end
if $arg0 == 0
printf "\n"
end
printf "TOTAL: %d (%d)\tUSED: %d (%d) \tFREE: %d (%d)\n", \
$used + $free, $numused + $numfree, \
$used, $numused, \
$free, $numfree
end
# rtems_helper_score_watchdog_chain
# ABSTRACT
# Verbosely list a single SuperCore Watchdog chain
# ARGUMENTS
# arg0 = pointer to Watchdog delta chain
define rtems_helper_score_watchdog_chain
set $permt = $arg0.permanent_null
set $node = $arg0.first
if $node == $permt
printf "Empty\n"
end
while $node != $permt
set $wnode = (Watchdog_Control *)$node
#print $wnode
printf "======================\n0x%x, %d handler=", \
$wnode, $wnode.delta_interval
print $wnode.routine
print/x *$wnode
set $node = $node.next
end
end
# rtems_helper_score_mutex
# ABSTRACT
# Verbosely list a single SuperCore mutex
# ARGUMENTS
# arg0 = pointer to the mutex
define rtems_helper_score_mutex
set $m = $arg0
set $CORE_MUTEX_DISCIPLINES_FIFO = 0
set $CORE_MUTEX_DISCIPLINES_PRIORITY = 1
set $CORE_MUTEX_DISCIPLINES_PRIORITY_INHERIT = 2
set $CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING = 3
set $d = $m->Attributes.discipline
if $d == $CORE_MUTEX_DISCIPLINES_FIFO
printf "FIFO "
end
if $d == $CORE_MUTEX_DISCIPLINES_PRIORITY
printf "PRIO "
end
if $d == $CORE_MUTEX_DISCIPLINES_PRIORITY_INHERIT
printf "INHT "
end
if $d == $CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING
printf "CEIL "
end
if $m->lock == 0
printf "LCK holder=0x%08x nest=%d\n", $m->holder_id, $m->nest_count
else
printf "UNL"
end
rtems_helper_score_threadq &$m->Wait_queue
end
# rtems_helper_score_semaphore
# ABSTRACT
# Verbosely list a single SuperCore semaphore
# ARGUMENTS
# arg0 = pointer to the semaphore
define rtems_helper_score_semaphore
set $s = $arg0
if $s->count == 0
printf "Unavailable "
rtems_helper_score_threadq &$s->Wait_queue
else
printf "Available Count=%d", $s->count
end
end
# rtems_helper_score_message_queue
# ABSTRACT
# Verbosely list a single SuperCore Message Queue
# ARGUMENTS
# arg0 = pointer to the message queue
define rtems_helper_score_message_queue
set $mq = $arg0
printf "%d/%d msgs ", \
$mq->number_of_pending_messages, $mq->maximum_pending_messages
if $mq->number_of_pending_messages == 0
rtems_helper_score_threadq &$mq->Wait_queue
end
end
######## Internal Objects
# ABSTRACT
# Verbosely list a single internal task
# ARGUMENTS
# arg0 = index in the _Information table
define rtems_internal_task
set $th_int_inf = (Objects_Information)_Thread_Internal_information
rtems_helper_show_task $th_int_inf $arg0
end
document rtems_internal_task
Usage: rtems_internal_task index
Displays detailed information about the specified internal RTEMS task
end
# ABSTRACT
# Dump all internal tasks
define rtems_internal_tasks
rtems_helper_show_tasks $th_int_inf
end
document rtems_internal_tasks
Usage: rtems_internal_tasks
Displays a list of all internal RTEMS tasks
end
######## Classic API
# ABSTRACT
# Dump all Classic tasks
define rtems_classic_tasks
set $rtems_task_info = (Objects_Information)_RTEMS_tasks_Information
rtems_helper_show_tasks $rtems_task_info
#_RTEMS_tasks_Information
end
document rtems_classic_tasks
Usage: rtems_classic_tasks
Displays a list of all Classic API RTEMS tasks
end
# ABSTRACT
# Verbosely list a single classic task
# ARGUMENTS
rtems_helper_show_task $rtems_task_info $arg0
#orifginale rtems_helper_show_task _RTEMS_tasks_Information $arg0
end
Usage: rtems_classic_task index
Displays detailed information about the specified Classic API task
end
# ABSTRACT
# Verbosely list a single Classic API semaphore
# ARGUMENTS
define rtems_classic_semaphore
set $inf = (Objects_Information)_Semaphore_Information
set $sem = (Semaphore_Control *)$inf.local_table[$arg0]
set $id = $sem->Object.id
set $name = (unsigned int)$sem->Object.name
# hack for is a mutex
if $sem->attribute_set != 0
printf " Mutex "
rtems_helper_score_mutex &$sem->Core_control.mutex
else
printf " Sem "
rtems_helper_score_semaphore &$sem->Core_control.semaphore
end
printf "\n"
end
document rtems_classic_semaphore
Usage: rtems_classic_semaphore index
Displays information about the specified Classic API Semaphore
end
# ABSTRACT
# Verbosely list all Classic API semaphores
# ARGUMENTS: NONE
define rtems_classic_semaphores
printf "\
printf "\
# | Name | ID | Information\n"
printf "\
---+------+----------+-----------------------------------------------\n"
set $index = 1
while $index <= $inf.maximum
set $pt = (Semaphore_Control *)$inf.local_table[$index]
if $pt != 0
rtems_classic_semaphore $index
end
end
end
document rtems_classic_semaphores
Usage: rtems_classic_semaphores
Displays a list of all Classic API Semaphores
end
# ABSTRACT
# Verbosely list a single Classic API Message Queue
# ARGUMENTS
define rtems_classic_message_queue
set $inf = (Objects_Information)_Message_queue_Information
set $queue = (Message_queue_Control *)$inf.local_table[$arg0]
set $id = $queue->Object.id
set $name = (unsigned int)$queue->Object.name
rtems_helper_score_message_queue &$queue->message_queue
printf "\n"
end
document rtems_classic_message_queue
Usage: rtems_classic_message_queue index
Displays information about the specified Classic API Message Queue
end
# ABSTRACT
# Verbosely list all Classic API Message Queues
# ARGUMENTS: NONE
define rtems_classic_message_queues
printf "\
printf "\
printf "\
set $index = 1
set $pt = (Message_queue_Control *)$inf.local_table[$index]
if $pt != 0
rtems_classic_message_queue $index
end
end
end
document rtems_classic_message_queues
Usage: rtems_classic_message_queues
Displays a list of all Classic API Message Queues
end
# ABSTRACT
# Verbosely list a single Classic API Region
# ARGUMENTS
define rtems_classic_region
set $inf = (Objects_Information)_Region_Information
set $r = (Region_Control *)$inf.local_table[$arg0]
set $id = $r->Object.id
set $name = (unsigned int)$r->Object.name
rtems_helper_score_heap &$r->Memory
printf "\n"
end
document rtems_classic_region
Usage: rtems_classic_region index
Displays information about the specified Classic API Region
end
# ABSTRACT
# Verbosely list all Classic API Regions
# ARGUMENTS: NONE
define rtems_classic_regions
printf "\
printf "\
printf "\
set $index = 1
set $pt = (Region_Control *)$inf.local_table[$index]
if $pt != 0
rtems_classic_region $index
end
end
end
document rtems_classic_regions
Usage: rtems_classic_regions
Displays a list of all Classic API Regions
end
######## POSIX API
# ABSTRACT
# Verbosely list a single POSIX thread
# ARGUMENTS
define rtems_posix_thread
set $pos_thr_inf = (Objects_Information)_POSIX_Threads_Information
rtems_helper_show_task $pos_thr_inf $arg0
end
document rtems_posix_thread
Usage: rtems_posix_thread index
Displays detailed information about the specified POSIX API thread
end
# ABSTRACT
# Dump all POSIX threads
# ARGUMENTS: NONE
define rtems_posix_threads
rtems_helper_show_tasks $pos_thr_inf
end
document rtems_posix_threads
Usage: rtems_posix_threads
Displays a list of all POSIX API threads
end
# ABSTRACT
# Verbosely list a single POSIX API semaphore
# ARGUMENTS
define rtems_posix_semaphore
set $inf = (Objects_Information)_POSIX_Semaphore_Information
set $sem = (POSIX_Semaphore_Control *)$inf.local_table[$arg0]
if $sem->named
printf "%s", (char *)$sem->Object.name
end
printf " %08x | ",$id
rtems_helper_score_semaphore &$sem->Semaphore
printf "\n"
end
document rtems_posix_semaphore
Usage: rtems_posix_semaphore index
Displays information about the specified POSIX API Semaphore
end
# ABSTRACT
# Verbosely list all POSIX API semaphores
# ARGUMENTS: NONE
define rtems_posix_semaphores
printf "\
printf "\
# | ID | Information\n"
printf "\
---+-----------+-----------------------------------------------\n"
set $index = 1
set $pt = (POSIX_Semaphore_Control *)$inf.local_table[$index]
if $pt != 0
rtems_posix_semaphore $index
end
end
end
document rtems_posix_semaphores
Usage: rtems_posix_semaphores
Displays a list of all POSIX API Semaphores
end
# rtems_posix_mutex
# ABSTRACT
# Verbosely list a single POSIX API mutex
# ARGUMENTS
define rtems_posix_mutex
set $inf = (Objects_Information)_POSIX_Mutex_Information
set $mutex = (POSIX_Mutex_Control *)$inf.local_table[$arg0]
set $id = $mutex->Object.id
rtems_helper_score_mutex &$mutex->Mutex
printf "\n"
end
document rtems_posix_mutex
Usage: rtems_posix_mutex index
end
# ABSTRACT
# Verbosely list all POSIX API mutexes
# ARGUMENTS: NONE
define rtems_posix_mutexes
printf "\
printf "\
printf "\
set $index = 1
set $pt = (POSIX_Mutex_Control *)$inf.local_table[$index]
if $pt != 0
rtems_posix_mutex $index
end
end
end
document rtems_posix_mutexes
Usage: rtems_posix_mutexes
Displays a list of all POSIX API Mutexes
end
######## General and Cross API
# rtems_tasks
# ABSTRACT
# Dump all tasks of all classes (internal, POSIX and Classic)
# ARGUMENTS: NONE
# TODO: For 4.6, check object information table for non-NULL
define rtems_tasks
set $th_exe = (Thread_Control *) _Thread_Executing
printf "Executing: 0x%x, Heir: 0x%x\n", $th_exe->Object.id, \
$th_exe.Object.id
printf
"================================================================\n"
printf "Internal Tasks\n"
printf
printf "Classic Tasks\n"
set $par = (Objects_Information)_RTEMS_tasks_Information
rtems_helper_show_tasks $par
printf
printf "POSIX Tasks\n"
set $posix_th = (Objects_Information)_POSIX_Threads_Information
rtems_helper_show_tasks $posix_th
end
document rtems_tasks
Usage: rtems_tasks
Displays a list of all internal and API defined tasks/threads
end
# ABSTRACT
# Verbosely list contents of ticks chain tickled from clock tick
# ARGUMENTS: NONE
define rtems_internal_ticks_chain
set $wd = (Chain_Control)_Watchdog_Ticks_chain
rtems_helper_score_watchdog_chain $wd
end
document rtems_internal_ticks_chain
Usage: rtems_internal_ticks_chain
Lists the contains of the internal RTEMS delta chain used to manage
all timing events that are tick based. This chain will contain
timeouts, delays, API defined timers, and the TOD update timer.
end
# ABSTRACT
# Verbosely list contents of seconds chain tickled from clock tick
# ARGUMENTS: NONE
define rtems_internal_seconds_chain
set $wd = (Chain_Control)_Watchdog_Seconds_chain
end
document rtems_internal_seconds_chain
Usage: rtems_internal_seconds_chain
all timing events that are TOD based.
end
# rtems_malloc_walk
# ABSTRACT
# Verbosely list the contents and state of the C Program Heap
# ARGUMENTS: None
define rtems_malloc_walk
set $reg_inf = (Objects_Information)_Region_Information
set $heap = &(((Region_Control *)\
$reg_inf->local_table[RTEMS_Malloc_Heap&0xffff])->Memory)
rtems_helper_score_heap $heap
end
document rtems_malloc_walk
Usage: rtems_malloc_walk
Display information about the C program heap
end
# ABSTRACT
# ARGUMENTS: None
define rtems_workspace_walk
set $heap = (Heap_Control *)&_Workspace_Area
end
document rtems_workspace_walk
Usage: rtems_workspace_walk
Display information about the RTEMS Executive Workspace
end
# rtems_tod
# ABSTRACT
# Print out the current time of day
# ARGUMENTS: NONE
define rtems_tod
set $tod = (TOD_Control)_TOD_Current
printf "Current Time MM/DD/YYYY HH:MM:SS -- %02d/%02d/%d
%02d:%02d:%02d\n", \
$tod.month, $tod.day, $tod.year, \
$tod.hour, $tod.minute, $tod.second
end
document rtems_tod
Usage: rtems_tod
Display the current time of day according to RTEMS
NOTE: If the TOD is not set, it will start at 1988.
end
# rtems_check_state
# ABSTRACT
# Check system state, dispatching critical section and ISR states
# ARGUMENTS: NONE
define rtems_check_state
printf "RTEMS System State is: \n "
p _System_state_Current
# Check Thread Dispatching Critical Sections
set $tddl = _Thread_Dispatch_disable_level
if $tddl == 0
printf "NOT inside dispatching critical section\n"
end
if $tddl != 0
printf "Inside dispatching critical section -- level = %d\n", $tddl
if $tddl >= 100
printf "HIGHLY PROBABLY DISPATCHING CRITICAL SECTION ERROR\n"
end
end
# Check ISR Nesting and Dispatching Critical Sections
set $isrnl = _ISR_Nest_level
if $isrnl == 0
printf "NOT inside an ISR\n"
end
if $isrnl != 0
printf "Inside interrupt -- nest level = %d\n", $isrnl
if $isrnl > $tddl
printf "ISR NEST LEVEL SHOULD ALWAYS BE >= DISPATCH DISABLE LEVEL\n"
end
if $isrnl < $tddl
printf "It looks like you interrupted a dispatching critical
section\n"
end
end
end
document rtems_check_state
Usage: rtems_check_state
This method displays information about the current state of RTEMS
including
dispatching disable critical sections and ISR nesting. It performs some
rudimentary consistency checks which might highlight problems.
end
>From: Joel Sherrill <joel.sherrill at oarcorp.com>
>To: Luca Germano <lucagermano at hotmail.com>
>CC: paulw at omnitronics.com.au, leonp at plris.com, rtems-users at rtems.com
>Subject: Re: GDB macros
>Date: Wed, 13 Sep 2006 11:36:12 -0500
>Luca Germano wrote:
>>Hi, thanks for your help.
>>I'm using the GDB macros version of the rtems wiki. I'm using RTEMS on
>>Leon3 CPU.
>>I find the problems.
>>When a macro refers to an RTEMS global variables is necessary to cast the
>>variables to the primitive type of the variable to be able to access its
>>fields. Doing the cast the macros work fine. For examples in the
>>rtems_classic_tasks macros I can't use directly _RTEMS_tasks_Information
>>but I must do
>>set $prova = (Objects_Information)_RTEMS_tasks_Information
>>rtems_helper_show_task $prova $arg0
>>instead of
>>In some macro there are some pointer conversion cast for example
>>(Thread_Control_struct *)
>>Also this instraction doesn't work. I must use
>>(Thread_Control *)
>>Now I must correct all the macros.
>Thanks. Please update the source code in the Wiki.
>And if you have any ideas for other helper macros or tweaks to existing
>functions,
>please speak up. These macros have grown more out of user need than
>anything
>else.
>>The ultimate thing to set is the macro rtems_task_backtrack that is HW
>>dependent. Someone know the field of the structure Register of the RTEMS
>>context switch to use for Leon3?
>For every architecture, this is the structure Context_Control defined in
>cpukit/score/CPUNAME/rtems/score/cpu.h.
>For SPARC, I think you want to try either i6_fp or o6_sp. One of those
>should work.
>>Best Regards
>>Luca Germano
>>>From: Paul Whitfield <paulw at omnitronics.com.au>
>>>CC: leonp at plris.com, rtems-users at rtems.com
>>>Date: Wed, 13 Sep 2006 08:54:54 +0800
>>>Luca Germano wrote:
>>>>I put a breakpoint in the program. After program execution stop on the
>>>>breakpoint I execute the macro.
>>>>Luca
>>>>>From: leonp at plris.com
>>>>>To: rtems-users at rtems.com
>>>>>Date: Tue, 12 Sep 2006 11:41:08 +0300
>>>>>On Tuesday, 12 ×September 2006 11:37, Luca Germano wrote:
>>>>> > Thanks for the help.
>>>>> > I try to use the rtems_classic_tasks macro but gdb give me the
>>>>>following
>>>>> > reply
>>>>> > Attempt to extract a component of a value that is not a structure.
>>>>> > How can I solve this problem?
>>>>>Is the program running? I mean have you stopped it in the middle of the
>>>>>execution and them executed the macro?
>>>Hi Luca,
>>>Which version of the Macros are you using?
>>>Make sure you are using the latest ones from the rtems wiki.
>>>Also I have found in the past you need to use the command line
>>>version of gdb to debug the macros, if you use a GUI/IDE interface
>>>such as insight or emacs it hides error messages from you which
>>>makes it difficult to debug the problem(s).
>>>Regards
>>>Paul
>>>The information in this e-mail is intended for the addressee only.
>>>Unauthorised use, copying, disclosure or distribution by anyone else
>>>is prohibited. Please let us know immediately if you receive this
>>>e-mail in error. Thank you.
