Dynamic Libraries
Marek Prochazka
Marek.Prochazka at scisys.co.uk
Mon Sep 18 09:18:42 UTC 2006
Till,
This fixed the problem and it works O.K. now!
I very much appreciate your help!
Best regards,
Marek
> -----Original Message-----
> From: Till Straumann [mailto:strauman at slac.stanford.edu]
> Sent: 14 September 2006 22:53
> To: RTEMS Users Mailing List
> Subject: Re: Dynamic Libraries
> Marek.
> Regardless of a possible fix to your linker script -- here is
> a workaround:
> Symbols for the sections are not really needed and you can
> simply delete
> them from the generated 'symbolfile.c' and not use the linker
> script at all
> (or just delete the offending ones).
> To make life easier, I added a new [-s] option to xsyms which you have
> to enable in order to produce entries for the section symbols
> in the table.
> I.e., if you don't use -s you should be OK.
> HTH
> -- Till
> Marek Prochazka wrote:
> >> I simply didn't get a chance to look at it [don't have any
> >> sparc tools
> >> installed].
> >> What BSP are you using - I could give it a try.
> > I use this:
> > BSP NAME: sis
> > BOARD: any based on the European Space Agency's ERC32
> > BUS: N/A
> > CPU FAMILY: sparc
> > CPU: ERC32 (SPARC V7 + on-CPU peripherals) based on
> > Cypress 601/602
> > COPROCESSORS: on-chip 602 compatible FPU
> > MODE: 32 bit mode
> > My target platform is Leon2.
> >> Also: please send me a full console log of the failing
> build command.
> > /opt/rtems-4.6/bin/sparc-rtems-gcc -g -DCDS_DEBUG_VERSION -Wall -W
> > -ansi -pedantic -DG_RTEMS_VERSION -DG_LEON_VERSION
> > -DG_SPACEWIRE_VERSION -D_POSIX_C_SOURCE=199506L -msoft-float -qleon2
> > -I./inc -I/home/marek/work/DRIVERS/UDP/inc
> > -I/home/marek/work/DRIVERS/LEON_SPW/inc
> > -I/home/marek/work/SOIS/Tools/MA_Emulation/inc
> > -I/home/marek/work/SOIS/Tools/DAS_Device_Emulation/inc
> > -D_MICROORB_RTCORBA_THREADPOOL_WITH_LANES -I./idl
> -I../cexp-1.5 Loader.o
> > -L../cexp-1.5/build-rtems -L../cexp-1.5/build-rtems/regexp
> > -L../cexp-1.5/build-rtems/binutils/bfd
> > -L../cexp-1.5/build-rtems/binutils/libiberty
> > -L../cexp-1.5/build-rtems/binutils/opcodes -lcexp
> -lspencer_regexp -lbfd
> > -liberty -lopcodes -L/home/marek/work/lib -L/home/marek/work/BSW/lib
> > -L/home/marek/work/SOIS/CMS/lib
> -L/home/marek/work/SOIS/CMS_Config/lib
> > -L/home/marek/work/SOIS/MMS/lib
> -L/home/marek/work/DisCo/SOM/IFAS/lib
> > -L/home/marek/work/DisCo/SOM/FDIR/lib
> > -L/home/marek/work/DRIVERS/LEON_SPW/lib -lMMS_RTEMS_LEON_debug
> > -lCMS_RTEMS_LEON_debug -lspwCtm -lBSW_RTEMS_debug -o Loader
> > --------- Generating SYSTEM symbol table
> > ../cexp-1.5/build-host/xsyms -C Loader Symbols.c > link_helper
> > --------- Compiling SYSTEM symbol table
> > /opt/rtems-4.6/bin/sparc-rtems-gcc -c -fomit-frame-pointer -fasm -O
> > -I../cexp-1.5 Symbols.c
> > --------- Linking Loader application - second pass
> > -I./inc -D_MICROORB_RTCORBA_THREADPOOL_WITH_LANES -I./idl
> -I../cexp-1.5
> > Symbols.o Loader.o link_helper -L../cexp-1.5/build-rtems
> /opt/rtems-4.6/lib/gcc-lib/sparc-rtems/3.2.3/../../../../sparc
> -rtems/bin
> > /ld: ADDR forward reference of section .text
> > collect2: ld returned 1 exit status
> > make: *** [t] Error 1
> > link_helper:
> > __cexp__dummy_alias_0 = ADDR( .text ) ;
> > __cexp__dummy_alias_1 = ADDR( .data ) ;
> > __cexp__dummy_alias_2 = ADDR( .bss ) ;
> > __cexp__dummy_alias_3 = ADDR( .jcr ) ;
> > Many thanks,
> > Marek
> >> -- Till
> >>> Please, anyone having a hint how to deal with the problem
> described
> >>> below? Or should I consider the issue being hard to solve
> >> in an easy way
> >>> and hence Cexp not being able to use on sparc-rtems? Sorry
> >> but I have to
> >>> keep pushing as I have to decide reasonably quickly whether
> >> I can use
> >>> Cexp for my project or not.
> >>> Thanks.
> >>> Best regards,
> >>> Marek Prochazka
> >>>> From: Marek Prochazka [mailto:Marek.Prochazka at scisys.co.uk]
> >>>> Sent: 12 September 2006 17:18
> >>>> To: Till Straumann
> >>>> Cc: rtems-users at rtems.com
> >>>> Subject: RE: Dynamic Libraries
> >>>> Hi,
> >>>> I have successfully linked a Cexp "loader" application on
> >>>> Linux and was
> >>>> able to load modules at runtime. Quite good stuff!
> >>>> When I am trying to do the same for sparc-rtems target, I get the
> >>>> following message when linking:
> >>>> -rtems/bin
> >>>> My link_helper file looks like this:
> >>>> Corresponding part of mysymbtab.c is
> >>>> static CexpSymRec systemSymbols[] = {
> >>>> .name =".text",
> >>>> .value.ptv =(void*)&__cexp__dummy_alias_0,
> >>>> .value.type =TVoid,
> >>>> .size =0,
> >>>> .flags =0|CEXP_SYMFLG_SECT,
> >>>> .name =".data",
> >>>> .value.ptv =(void*)&__cexp__dummy_alias_1,
> >>>> .value.type =TVoid,
> >>>> .size =0,
> >>>> .name =".bss",
> >>>> .value.ptv =(void*)&__cexp__dummy_alias_2,
> >>>> .value.type =TVoid,
> >>>> .size =0,
> >>>> .name =".jcr",
> >>>> .value.ptv =(void*)&__cexp__dummy_alias_3,
> >>>> .value.type =TVoid,
> >>>> .size =0,
> >>>> I have built libcexp for sparc-rtems and xsyms on Linux for
> >>>> sparc-rtems
> >>>> target. When I tried to build xsyms on top of libelf
> (--disable-bfd
> >>>> --disable-cexp) then the mysymtab.c file generated by xsyms
> >>>> is actually
> >>>> a binary file - so I do not know how use it.
> >>>> Any hints related to this?
> >>>> Many thanks,
> >>>> Marek
> >>>>> Sent: 12 September 2006 09:28
> >>>>> To: Till Straumann
> >>>>> Hi,
> >>>>> thanks, this helped me to link it! BTW my version of the
> >>>> README file,
> >>>>> which comes from Cexp 1.5 sources downloaded from the Cexp
> >>>> home page,
> >>>>> does not mention the trick with "> link_helper" in points
> >> 2) and 4).
> >>>>> Regards,
> >>>>> Marek
> >>>>>> Allan is correct. RTMF (see step 4), please [from the README]:
> >>>>>> > 1) compile and link all sources, libraries etc.; build an
> >>>>>> executable
> >>>>>> > 2) xsyms -C executable mysymtab.c > link_helper
> >>>>>> > 3) compile mysymtab.c (set -I to Cexp source
> directory, since
> >>>>>> > cexpsyms.h is included)
> >>>>>> > 4) link application again, but this time add
> >>>> 'mysymtab.c' to the
> >>>>>> > list of sources and 'link_helper' to the list
> of files to
> >>>>>> > be linked.
> >>>>>> > NOTE: Step 1) linking succeeds without a symtab.o
> >>>>> because there's
> >>>>>> > a weak NULL-ptr alias for the builtin symtab.
> >>>>>> HTH
> >>>>>> -- Till
