NFS Performance
Eric Norum
norume at aps.anl.gov
Mon Sep 18 13:13:48 UTC 2006
I'd like to state my objection to this. I don't think that it's a
good idea to have an API with different arguments to the same function.
May I suggest instead that:
1) All the ifdefs be removed fromt the nfs code.
2) A new function be added:
nfsInitWithBufferSize(int smallPoolDepth, int bigPoolDepth, int
bufferSize);
The existing nfsInit would call this with the existing size, so all
old code would continue to work. Code that wants to specify a buffer
size would use the new function.
On Sep 15, 2006, at 7:11 PM, Steven Johnson wrote:
> Hi
>> Sound's fine. Changing it there is quite easy. I think it should
>> default to 8K, and let the user tune it down by way of a sysctl. Ill
>> have the code added and tested, if it turns out OK, (which i
>> suspect it
>> will) I will post the patch.
> As promised, see attached patches. 1 for nfs.h, and 2 for nfs.c
> The nfs.h patch and 1 of the nfs.c patches
> (nfs_settable_buffer_size.patch) are for the HAVE_BLKSIZE define.
> The way we approached it is that if HAVE_BLKSIZE is defined, then an
> extra parameter must be passed to nfs_init, specifying the size of the
> block to use. If 0 is passed for this, it defaults to the best block
> size (which seems to be 8K for us). Any other value up to 8K sets the
> block size to this (over 8K sets it to 8K). Then the code changes in
> nfs.c are also controller by the same #def. The reason we did it this
> way, is so that if this define is not used, the existing behaviour
> will
> prevail. If this is defined, then the new behaviour kicks in and the
> block size must be specified when nfs is initialised. We couldn't see
> any value in it being able to be changed on the fly after
> initialisation. For debug purposes, it is a stored as a static
> variable, and so could be changed by a debugger to test different
> block
> sizes very easily.
> The second patch to nfs.c is in regard to the big pool which was only
> being used on a symlink and a write, it is equally useful for a
> read so
> this patch allows the pool to be big pool on a read, instead of small
> pool as it does now. I don't know if this makes things better, but it
> certainly doesn't hurt (us anyway).
> Steven Johnson
> --- librtemsNfs.h 2006-06-10 04:44:03.000000000 +1000
> +++ /tmp/librtemsNfs.h 2006-09-15 08:43:34.309866851 +1000
> @@ -110,7 +110,11 @@
> * driver chose reasonable defaults.
> int
> +#ifdef HAVE_BLKSIZE
> +nfsInit(int smallPoolDepth, int bigPoolDepth, int bufferSize);
> +#else
> nfsInit(int smallPoolDepth, int bigPoolDepth);
> +#endif
> /* Driver cleanup code
> --- nfs.c 2006-06-10 04:44:03.000000000 +1000
> +++ /tmp/nfs.c 2006-09-15 08:40:42.085342962 +1000
> @@ -1075,6 +1075,7 @@
> switch (proc) {
> case NFSPROC_SYMLINK:
> case NFSPROC_WRITE:
> + case NFSPROC_READ:
> pool = bigPool; break;
> default: pool = smallPool; break;
> +++ /tmp/nfs.c 2006-09-15 09:11:13.327813709 +1000
> @@ -182,6 +182,16 @@
> #define UNLOCK(s) do { rtems_semaphore_release((s)); \
> } while (0)
> +This nfs client gets its read buffer size from the fattr data from
> the
> +NFS server it connects to. If HAVE_BLKSIZE is set then this is
> +overridden and nfsInit takes a third parameter to set the buffer
> size.
> +That parameter is stored in NFS_BUFFER_SIZE
> +static int NFS_BUFFER_SIZE;
> +#endif
> Types with Associated XDR Routines
> @@ -930,7 +940,11 @@
> * on the fly).
> void
> +#else
> +#endif
> entry dummy;
> @@ -938,7 +952,14 @@
> fprintf(stderr,"($Id: nfs.c,v 1.2 2006/06/09 18:44:03 ericn Exp $)
> \n\n");
> fprintf(stderr,"Till Straumann, Stanford/SLAC/SSRL 2002\n");
> fprintf(stderr,"See LICENSE file for licensing info\n");
> + if ((bufferSize > 0) && (bufferSize < NFS_MAXDATA)) {
> + NFS_BUFFER_SIZE = bufferSize;
> + } else {
> + NFS_BUFFER_SIZE = NFS_MAXDATA;
> +#endif
> /* Get a major number */
> if (RTEMS_SUCCESSFUL != rtems_io_register_driver(0, &drvNfs,
> &nfsGlob.nfs_major)) {
> @@ -2834,7 +2855,11 @@
> buf->st_uid = fa->uid;
> buf->st_gid = fa->gid;
> buf->st_size = fa->size;
> + buf->st_blksize = NFS_BUFFER_SIZE;
> +#else
> /* TODO: set to "preferred size" of this NFS client
> implementation */
> buf->st_blksize = fa->blocksize;
> +#endif
> buf->st_rdev = fa->rdev;
> buf->st_blocks = fa->blocks;
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
