C compiler cannot create executables
Mon Apr 2 11:12:44 UTC 2007
Amalaye Oyake wrote:
> Fixed:
> While my autoconf was up to date, my automake was not. Debian/Ubuntu users
> take note (since I am using the latest Ubuntu ~ Edgy) ... I manually brought
> automake to v 10 (Edgy still seems to use an old automake) and everything
> seems happy - bootstrap is chugging as I speak.
Does the edge of the 4.7 branch compile now for you?
It looks like a good time for 4.7.1 if it does.
--joel
> -----Original Message-----
> From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
> [mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On Behalf
> Of Amalaye Oyake
> Sent: Friday, March 30, 2007 12:33 PM
> To: 'Ralf Corsepius'
> Cc: rtems-users at rtems.org
> Subject: FW: C compiler cannot create executables
> Ok, I have checked out that branch. The instructions say use the ./bootstrap
> script, but that script seems to bomb miserably.
> /RTEMS_latest/rtems$ ./bootstrap
> cp: cannot create regular file `[$1]/install-sh': No such file or directory
> automake: configure.ac: installing `[$1]/install-sh'
>     error while copying
> blah blah blah
> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
> Sent: Thursday, March 29, 2007 2:03 PM
> To: Amalaye Oyake
> Subject: Re: C compiler cannot create executables
> On Thu, 2007-03-29 at 10:40 -0700, Amalaye Oyake wrote:
>> I was rebuilding RTEMS and I was running into this problem:
>> checking for C compiler default output file name... configure: error: C
>> compiler cannot create executables.
>> I am assuming that configure was using the cross compiler tools that I
> built
>> ... it seemed to build everything else just fine, but kept getting hung
> here
>> ~ pc386/configure failed for pc386.
> I presume this to be a known issue with the 4.7.0 release and building
> i386 targets on non-multilib'ed x86_64 systems.
> Can you try with RTEMS CVS from rtems-4-7-branch?
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
