Move/Rename FAT file
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Thu Apr 5 15:50:57 UTC 2007
Hi,
renaming files seems to be the topic of the week :-)
renaming should work fine on a RTEMS FAT filesystem. Can you provide
some more information:
- which RTEMS version do you use?
- are you sure there is no file with the "new" name already present?
(This might be a problem)
- Can you provide some sample code?
wkr,
Thomas.
Camilo Alejandro Arboleda schrieb:
> Hello,
> I'm trying to use "rename" function in a mounted FAT volume, but it doesn't
> seem to work, should it work? is there any way to move a file in RTEMS?
> Thanks in advance,
> Camilo A. Arboleda
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
