RFC eliminating zeroing of heap/workspace
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Thu Apr 5 22:05:13 UTC 2007
Joel Sherrill schrieb:
> Thomas Doerfler wrote:
>> 2.) The behaviour of systems is a bit more repeatable when the memory is
>> set to a known state after boot
> Agreed and if this is the case, then the BSP certainly has the option of
> turning on the cpu_table.do_zero flag.
>> These are not really striking arguments, so I am a bit torn between
>> zeroing memory or not. And no, I don't think this is worth another
>> general RTEMS configuration option :-)
> It already is. :)  I just changed the default in bspstart.c from TRUE to
> FALSE. :)
ok, wow, I really forgot about this. Switching it off by default seems
nice for me.
>> wkr,
>> Thomas.
>>> On Apr 5, 2007, at 3:58 PM, Joel Sherrill wrote:
>>>> Hi,
>>>> I have done some investigation on a simulator
>>>> and determined that much of the time required
>>>> to bring the minimum test from reset to the
>>>> first task is consumed by zero'ing the
>>>> C Program Heap and RTEMS Workspace.
>>>> My testing is on a simulated system which
>>>> has 4MB of RAM and zeroes all but maybe
>>>> 64K of it since that is the code and data.
>>>> It takes 97% of the boot time to clear this
>>>> much RAM.
>>>> What's the general sentiment about clearing:
>>>> + the C program heap
>>>> + the RTEMS workspace
>>>> Just wanting opinions and thoughts.
>>>> --joel
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
