Semaphores macro error
Wed Apr 11 13:54:24 UTC 2007
Leon Pollak wrote:
> Hello, all.
> I try to use the rtems_classic_semaphores gdb script and receive the
> following:
> (gdb) rtems_classic_semaphores
>  # | Name |    ID    | Information
>  1 | LBIO | 1a010001 |   Mutex INHT UNL  PRIO -
> No memory available to program: call to malloc failed
> I am sure that there is plenty of memory in the system, so the error message
> is about something else. Which type of memory and from what area this script
> try to get?
The macros are not supposed to run anything on target hardware.
But grep'ing the gdb source, I see this:
./gdb/valops.c: error (_("No memory available to program: call to malloc
failed"));
which appears to indicate that the script tried.   It looks like it made
it down to
rtems_helper_score_threadq and that tried to do something on the target but
I don't see anything particularly unusual about what it is doing.  Do you?
--joel
> Thanks.
