Task notepad and name problem
Wed Apr 18 11:28:49 UTC 2007
Leon Pollak wrote:
> Hello.
> I have the following problem:
> I need to know the task name using its ID. I did not find anything in user's
> manual helping in this therefore I think to use notepad to store the task
> name and retrieve it from there.
> As there was a discussion previously about the notepads, may be this is the
> case where they may be useful?
> Or is there any other solution?
Maybe this will work for you..... :)
rtems_status_code rtems_object_id_to_name(
  rtems_id      id,
  rtems_name   *name
It has existed a while but was not added to the user's manual.  I spotted
another one of those cases after cutting 4.7.1 :(
--joel
> Thanks.
