automake do not work in rtems4.8-arm-1.exe
ray
xr at trasin.net
Tue Apr 24 13:53:24 UTC 2007
Hi
I download the rtems4.8-arm-1.exe from /ftp/pub/rtems/windows/. I install it (it
is very easy to install). But seems it do not work :(
Here is the error message for automake
$ automake
Can't locate Automake/Struct.pm in @INC (@INC contains: /home2/work/chris/rtems/
4.7/build/rpms/share/automake-1.10 /usr/lib/perl5/5.8/cygwin /usr/lib/perl5/5.8
/usr/lib/perl5/site_perl/5.8/cygwin /usr/lib/perl5/site_perl/5.8 /usr/lib/perl5/
site_perl/5.8/cygwin /usr/lib/perl5/site_perl/5.8 /usr/lib/perl5/vendor_perl/5.8
/cygwin /usr/lib/perl5/vendor_perl/5.8 /usr/lib/perl5/vendor_perl/5.8/cygwin /us
r/lib/perl5/vendor_perl/5.8 .) at /rtems/cross/arm-rtems/bin/automake line 48.
BEGIN failed--compilation aborted at /rtems/cross/arm-rtems/bin/automake line 48
and the rtems do not make:
arm-rtems4.8-gcc --pipe -DHAVE_CONFIG_H -I../../.. -I../../../../cpukit/../../
../csb337/lib/include -Wall -fasm -mcpu=arm920 -mstructure-size-boundary=8 -O2
-g -MT libscorecpu_a-cpu.o -MD -MP -MF .deps/libscorecpu_a-cpu.Tpo -c -o libsco
recpu_a-cpu.o `test -f 'cpu.c' || echo '/rtems/src/rtems-4.7.99.1/c/src/../../cp
ukit/score/cpu/arm/'`cpu.c
arm-rtems4.8-gcc.exe: /rtems/src/rtems-4.7.99.1/c/src/../../cpukit/score/cpu/arm
/cpu.c: No such file or directory
Thanks & Best Regards!
ray
2007-04-24
