No subject
Vivian Paola Guerrero Rodriguez
vivianpaolag at hotmail.com
Wed Apr 25 15:20:08 UTC 2007
Hi,
i'm installing rtems with the file rtems-4.7.1.tar.bz2 and
rtems4.7-i386-4.exe as development environment on my pc winxp using cygwin.
at first, I compile the configure :
$ ../src/rtems-4.7.1/configure --disable-tests --enable-multilib
--target=i386-rtems4.8 --prefix=/cygdrive/c/rtems/i386
/ --enable-posix --enable-networking --enable-cxx --enable-rtemsbsp="pc386
pc486"
it creates the make files , after that i carry out the line
$ make all install
and there appears a error *** multiple target patterns. Stop. Something
like this:
Making all in score
make[6]: Entering directory
`/cygdrive/c/rtems-source/build/i386-rtems4.8/m486/cpukit/score'
src/.deps/libscore_a-apiext.Po:1: *** multiple target patterns. Stop.
make[6]: Leaving directory
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory
`/cygdrive/c/rtems-source/build/i386-rtems4.8/m486/cpukit'
make[4]: *** [all] Error 2
make[4]: Leaving directory
make[3]: *** [multi-do] Error 1
make[3]: Leaving directory
`/cygdrive/c/rtems-source/build/i386-rtems4.8/cpukit'
make[2]: *** [all-multi] Error 2
make[2]: Leaving directory
make[1]: *** [all] Error 2
make[1]: Leaving directory
make: *** [all-recursive] Error 1
I thank you every advice for this problem
_________________________________________________________________
Exercise your brain! Try Flexicon.
http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07
