RTEMS Timer problem
hwulf at et-inf.fho-emden.de
Wed Apr 4 08:40:43 UTC 2007
----- Weitergeleitete Nachricht von hwulf at et-inf.fho-emden.de -----
Datum: Wed, 4 Apr 2007 10:00:03 +0200
Von: hwulf at et-inf.fho-emden.de
Antwort an: hwulf at et-inf.fho-emden.de
Betreff: Re: RTEMS Timer problem
An: Joel Sherrill <joel.sherrill at oarcorp.com>
I see. I just deleted the timer driver, the clock driver
was already defined before. Some tests show, that the timer
interrupt routine (timerISR) isn't gonna be called.
I passed the name "timerISR" as an argument to rtems_timer_fire_after()
in the function activateTimer(). The data type
rtems_timer_service_routine_entry
is just a function pointer, isn't it? So I could insert timerISR or &timerISR?
What datatypes are rtems_timer_service_routine and
rtems_timer_service_routine_entry?
Thank you very much in advance,
Hank
Quoting Joel Sherrill <joel.sherrill at oarcorp.com>:
> hwulf at et-inf.fho-emden.de wrote:
>> Hi,
>> I wanted to configure a timer, whose ISR sends an event to a user task.
>> But unfortunately, the timer doesn't seem to expire.
>> I already defined CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER and
>> CONFIGURE_MAXIMUM_TIMERS 3 in the main module.
> The Timer driver is a benchmark timer. You need the Clock driver not
> the Timer driver.
> --joel
>> Are there some other configurations or processor-registers to set in
>> order to get the timer started?
>> Below is the code of the user task and the important functions from my
>> timer module.
>> I'm running the RTEMS program in TSIM.
>> I thank you very much for every advice in advance!
>> Kind regards,
>> Hank
>> * USER_TASK1
>> rtems_task user_task_1(rtems_task_argument unused)
>> rtems_status_code status;
>> rtems_event_set task1_event;
>> printf("Task 1: Creating Timer\n");
>> createTimer(&tTimer[0], Timer_name[0], TIMER_PERIODIC, 100);
>> printf("Task 1: Activating Timer\n");
>> activateTimer(tTimer[0]);
>> while(TRUE)
>> int i = 0;
>> waitForTimerEvent(task1_event, 2*TIMER_INTERVAL);
>> i++;
>> printf("Task 1: Event #%i received", i);
>> return(status);
>> rtems_timer_service_routine timerISR(rtems_id timer_id, void *user_data)
>> int i;
>> /* restart timer with the same interval */
>> rtems_timer_reset(timer_id);
>> /* send event to particular task */
>> for(i = 0; i < MAXIMUM_TIMER_TASKS; i++)
>> if(Timer_id[i] == timer_id)
>> rtems_event_send(Task_id[i], RTEMS_EVENT_0);
>> break;
>> rtems_status_code createTimer(struct obdhtimer_t *tTimer,
>> rtems_name name, enum timer_mode mode, rtems_interval interval)
>> tTimer->mode = mode;
>> tTimer->interval = interval;
>> status = rtems_timer_create(name, &(tTimer->id));
>> return(status);
>> rtems_status_code activateTimer(struct obdhtimer_t tTimer)
>> status = rtems_timer_fire_after(tTimer.id, tTimer.interval,
>> timerISR, NULL);
>> return(status);
>> rtems_status_code waitForTimerEvent(rtems_event_set *event_out,
>> rtems_interval timeout)
>> status = rtems_event_receive(RTEMS_EVENT_0, RTEMS_WAIT |
>> RTEMS_EVENT_ANY, timeout, event_out);
>> return(status);
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
----- Ende der weitergeleiteten Nachricht -----
