Accessing the serial port with RTEMS
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Apr 20 13:23:14 UTC 2007
hwulf at et-inf.fho-emden.de wrote:
> When I print out an error message with perror(),
> it says "Too many open files in system"
> Why is this?
Because there are too many open files in the system. :)
The default configuration is for 3 file descriptors -- stdin,
stdout, and stderr. You need to change the value of this
configuration parameter.
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 3
Discussed in the documentation here:
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.7.1/share/rtems/html/c_user/c_user00389.html
--joel
> Thank you very much and kind regards,
> Hank
> Quoting hwulf at et-inf.fho-emden.de:
>> Hi,
>> I wanted to access the serial port with RTEMS.
>> As RTEMS is compliant to the POSIX standard,
>> I thought of using the POSIX functions for it.
>> But I can't open the serial port with the open()
>> function. Does anyone have an advice of what's
>> wrong with the code?
>> Or is there another way to access the serial port?
>> Thank you very much in advance and kind regards,
>> Hank
>> * INCLUDES
>> #include <rtems.h>
>> #include <stdio.h>
>> #include <string.h>
>> #include <unistd.h>
>> #include <fcntl.h>
>> #include <errno.h>
>> #include <termios.h>
>> * FUNCTION PROTOTYPES
>> rtems_task Init(rtems_task_argument argument);
>> * GLOBAL VARIABLES
>> * Keep the names and IDs in global variables so another task can use them.
>> * CONFIGURATION INFORMATION
>> #include <bsp.h> /* for device driver prototypes */
>> #define CONFIGURE_INIT
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_MAXIMUM_TASKS 3
>> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 2
>> #define CONFIGURE_MAXIMUM_SEMAPHORES 5
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #define CONFIGURE_EXTRA_TASK_STACKS (2 * RTEMS_MINIMUM_STACK_SIZE)
>> #define CONFIGURE_MICROSECONDS_PER_TICK 10000
>> //#define CONFIGURE_TICKS_PER_TIMESLICE 5
>> //#define CONFIGURE_MEMORY_OVERHEAD 1000
>> //#define CONFIGURE_EXECUTIVE_RAM_WORK_AREA 1000
>> #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
>> RTEMS_NO_TIMESLICE | \
>> RTEMS_NO_ASR | \
>> RTEMS_INTERRUPT_LEVEL(0))
>> #define MAX_ITERATIONS 20
>> #define _DEBUG_
>> #include <confdefs.h>
>> * MACROS
>> * Macro to print an task name that is composed of ASCII characters.
>> #define put_name( _name, _crlf ) \
>> do { \
>> rtems_unsigned32 c0, c1, c2, c3; \
>> c0 = ((_name) >> 24) & 0xff; \
>> c1 = ((_name) >> 16) & 0xff; \
>> c2 = ((_name) >> 8) & 0xff; \
>> c3 = (_name) & 0xff; \
>> putchar( (char)c0 ); \
>> if ( c1 ) putchar( (char)c1 ); \
>> if ( c2 ) putchar( (char)c2 ); \
>> if ( c3 ) putchar( (char)c3 ); \
>> if ( (_crlf) ) \
>> putchar( '\n' ); \
>> } while (0)
>> * This allows us to view the "Test_task" instantiations as a set
>> * of numbered tasks by eliminating the number of application
>> * tasks created.
>> * In reality, this is too complex for the purposes of this
>> * example. It would have been easier to pass a task argument. :)
>> * But it shows how rtems_id's can sometimes be used.
>> #define task_number( tid ) \
>> ( rtems_get_index( tid ) - \
>> rtems_configuration_get_rtems_api_configuration()->number_of_initialization_tasks
>> #include <stdio.h>
>> * Shared data. Use them with semaphores only!
>> * Task1_postbox is protected by semaphore with ID 0,
>> * Task2_postbox is protected by semaphore with ID 1.
>> * INIT
>> rtems_status_code status;
>> int fd = 0;
>> struct termios options;
>> /* open the serial port */
>> fd = open("\\\\.\\CNCA0", O_RDWR | O_NOCTTY | O_NONBLOCK);
>> if(fd == -1)
>> printf("Could not open serial port \\.\CNCA0.\n");
>> else
>> fcntl(fd, F_SETFL, 0);
>> /* get the current options */
>> tcgetattr(fd, &options);
>> /* setting the baud rate */
>> cfsetispeed(&options, B19200);
>> cfsetospeed(&options, B19200);
>> /* set raw input, 1 second timeout */
>> options.c_cflag |= (CLOCAL | CREAD);
>> /* 8N1, no parity */
>> options.c_cflag &= ~PARENB;
>> options.c_cflag &= ~CSTOPB;
>> options.c_cflag &= ~CSIZE;
>> options.c_cflag |= CS8;
>> options.c_cflag &= ~(CRTSCTS); /* no hardware flow control */
>> options.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
>> options.c_oflag &= ~(OPOST);
>> options.c_cc[VMIN] = 0;
>> options.c_cc[VTIME] = 10;
>> /* set the options */
>> tcsetattr(fd, TCSANOW, &options);
>> if(write(fd, "ATZ\r", 4) < 0)
>> printf("write() of 4 bytes failed!\n");
>> exit(0);
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
