three quesions about filesytem
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Apr 20 13:41:59 UTC 2007
shizheng wrote:
> Hi:
> 1.
> rtems_libio_is_valid_perms always returns non-zero value,
> so I can't catch why it's called in IMFS_evaluate_permission and IMFS_eval_path.
> #define RTEMS_LIBIO_PERMS_RWX S_IRWXO
> * Verifies that the permission flag is valid.
> #define rtems_libio_is_valid_perms( _perm ) \
> (~ ((~RTEMS_LIBIO_PERMS_RWX) & _perm ))
This is only used to check for an assert condition. Did somehow a bit
get set in
the permissions that isn't even defined.
> 1.
> 2. Why isn't there a semaphore and reference count to protect IMFS
> nodes like dosfs?
The IMFS was developed primarily to support the development of the
filesystem infrastructure.
It was developed as a useful test aid for the software layer above it.
It was just an oversight.
Looked at another way.. this is open source. The IMFS was initially
released with just
a subset of the functionality it has now. People have added to it as
they require.
If you have a patch for this, it would be appreciated.
> 1. Let's suppose / and /mem are IMFS_DIRECTORY nodes, and
> /mem/file is an IMFS_MEMORY_FILE node. Then I can delete
> /mem/file while it's still in open progress. To prove this, you
> can create two task:
> rtems_task imfs_reader(rtems_task_argument argument)
> int open_status, stat_status;
> struct stat stat_buf;
> rtems_id tid;
> rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &tid );
> printf( "imfs_reader task was invoked with argument (%d) "
> "and has id of 0x%x\n", argument, tid );
> while(1){
> open_status = open("/dev/test", 0);
> sleep(2+argument);
> stat_status = stat("/dev/test", &stat_buf);
> if(open_status>=0 && stat_status==-1){
> printf("file deleted while still opened\n", argument);
> Print_time();
> exit(0);
> close(open_status);
> rtems_task imfs_writer(rtems_task_argument argument)
> rtems_id tid;
> printf( "imfs_writer task was invoked with argument (%d) "
> while(1){
> mknod("/dev/test", 0777|S_IFCHR, 0);
> sleep(2+argument);
> unlink("/dev/test");
> sleep(2+argument);
> After about 4 seconds, you can see "file deleted while still
> opened" on the screen.
Feel free to submit a test case and patch for this one.
> 1.
> 2. imfs_dir_close doesn't check the st_nlink member of an IMFS
> directory node.
> So such a scenario will cause memory leak:
> 1. suppose /emptydir is an empty IMFS directory
> 2. dirp = opendir("/emptydir");
> rmdir("/emptydir");
> closedir(dirp);
> 3. After rmdir calls imfs_dir_rmnod, the IMFS node of
> /emptydir has been
> Chain_Extract from the IMFS name tree, but can't be freed
> as a result of
> opendir. Because imfs_dir_close doesn't do any check, this
> IMFS node
> will never be freed.
> Question No 2 and 3 are very obvious, I'm very confused why you guys
> remain the code
> like that, so I guess you may think it's the application-user's
> responsiblity to do
> the synchronization, but why dosfs does the effort while IMFS doesn't.
> Thank you very much for bringing us such a good open-source real-time
> os to the world:)))
--joel
> best wishes from shizheng, University of Science and Technology of China
> rtems-users mailing list
> rtems-users at rtems.com
