select on UART
Thomas Dörfler
Thomas.Doerfler at embedded-brains.de
Fri Apr 27 10:20:08 UTC 2007
Hi,
AFAIK select is currently limited to sockets, so there is no select
support for serial or other devices. It would be a nice thing to add
select support to the termios layer, but this has not yet been implemented.
wkr,
Thomas.
Alexis Lefort schrieb:
> Hello all,
> I wrote a driver for my UART chip wich works fine, but the select() does
> not work.
> What do I have to do to make the select() work?
> I can't find the solution in the Rtems documentation.
> Regards,
> Alexis
> Ce message et toutes les pièces jointes sont confidentiels et établis a
> l'intention exclusive de ses destinataires. Toute modification, édition,
> utilisation ou diffusion non autorisée est interdite. Tout message
> électronique est susceptible d'altération. CXR Anderson Jacobson décline
> toute responsabilité au titre de ce message s'il a été altéré, déformé,
> falsifié, édité ou diffusé sans autorisation.
> This message and any attachments are confidential and intended solely
> for the addressees. Any unauthorised alteration, printing, use or
> dissemination is prohibited. E-mails are susceptible to alteration. CXR
> Anderson Jacobson shall not be liable for the message if altered,
> changed, falsified, printed or disseminated without authorisation.
> rtems-users mailing list
> rtems-users at rtems.com
