RES: RES: RES: RTEMS for ezKit533
Antonio G Giovanini Jr antonio at atos.com.br
Fri Aug 3 14:14:00 UTC 2007
Hi Joel,
I do not know why, but there is a typewriting error.
- po.l
+ p0.l
Sorry,
  _____
Antonio Garibaldi Giovanini Junior
Atos Automacao Industrial LTDA.
Website: http://www.atos.com.br
E-mail: antonio at atos.com.br <mailto:antonio at atos.com.br>
-----Mensagem original-----
De: rtems-users-bounces+antonio=atos.com.br at rtems.org
[mailto:rtems-users-bounces+antonio=atos.com.br at rtems.org]Em nome de Joel
Sherrill
Enviada em: sexta-feira, 3 de agosto de 2007 10:52
Para: RTEMS
Assunto: Re: RES: RES: RTEMS for ezKit533
In looking over my test build logs, I realized that the bfin wasn't
in the list of CPUs to cycle over. There is a compilation error with
the bfin/eZKit553 on the CVS head:
../../../../../../../../current/c/src/lib/libbsp/bfin/eZKit533/../shared/sta
rt/start.S:
Assembler messages:
rt/start.S:55:
Error: syntax error. Input text was po.l.
rt/start.S:55:
Error:
Any ideas?
--joel
Antonio G Giovanini Jr wrote:
> Hi Frank,
> I have never use u-boot, I have a ICE (ICEBear - http://www.section5.ch/),
> it works so well.
> Hello test should work on SKYEYE, but I think that skyeye do not have
> support to ezkit LEDs, it can be a problem.
> It is needed to enable SDRAM registers before load the software, so you
need
> a boot to prepare your system.
> Sincerely,
>   _____
> Atos Automa??o Industrial LTDA.
> De: 汪庆 [mailto:wang816qing at 163.com]
> Enviada em: sexta-feira, 3 de agosto de 2007 00:02
> Para: Antonio G Giovanini Jr
> Assunto: Re:RES: RTEMS for ezKit533
> Prioridade: Alta
> HI Giovanini:
>     I do some hello.exe test like:
>     First:I install the rpm (tool-chains) and the
> automake1.10,autoconf2.61,then configure rtems like
"../rtems-4.7.99.1/configure --target=bfin-rtems4.8 --quiet --enable-posix -
> -disable-networking --enable-itron --enable-rtemsbsp="eZKit533" --prefix=/
op
> t/rtems-4.8",at last make rtems,but the run result  like this"ezkit> tftp
> 1000 hello.exe
> Using MAC Address 00:E0:22:FE:B4:50
> TFTP from server 192.168.0.101; our IP address is 192.168.0.254
> Filename 'hello.exe'.
> Load address: 0x1000
> Loading: #################################################################
> done
> Bytes transferred = 2411704 (24ccb8 hex)
> ezkit> bootelf 1000
> Loading .text @ 0x00001000 (79104 bytes)
> ## Starting application at 0xe1489348 ..." or "ezkit> tftp 1000000
hello.exe
> Load address: 0x1000000
> done
> ezkit> bootm
> ## Booting image at 01000000 ...
> Bad Magic Number
> ezkit> bootelf 1000000
> Loading .data @ 0x00014500 (3516 bytes)
> Clearing .bss @ 0x000152bc (598276 bytes)
> ## Starting application at 0x00001000 ..."
> which both not display "hello world" and the mcu dead.
>       Second: from above I think the code may go wrong,so I want to add
some
> LED test ,the asm code is from the bfin example for ezkit533(Flink
LED),and
> the compile result hello.exe,I debug it with Skyeye ,when run to some asm
> instruction in last letter,and it detach from gdb. Then I download to
SDRAM
> with tftp.the result is the same with The Fisrt one.
>       So now I don't how to do.I use the u-boot of bfin-uclinux,I am
afraid
> my problem is caused by it?
>      Others I wat to ask you what the bootrom and kernal for RTEMS,do we
> need to compile them alone and then flash them into Flash?
>      Thank you for your reply.
>                                                           Frank
> 在2007-08-02,"Antonio G Giovanini Jr" <antonio at atos.com.br> 写道:
> Hello Frank,
> I am not a RTEMS guru, but I participated in the blackfin port
development.
> I had success running Hello, ticker and others tests on ezkit533. Could
you
> tell about your problems to run hello on ezkit?
> I did not have any problems with ASM instructions yet. I did not find
follow
> assembler lines on hello test code.
> Sincerely,
>  _____
> [mailto:rtems-users-bounces+antonio=atos.com.br at rtems.org]Em nome de 汪庆
> Enviada em: quinta-feira, 2 de agosto de 2007 00:14
> Para: rtems-users at rtems.org
> Assunto: RTEMS for ezKit533
> Prioridade: Alta
> Hello RTEMS gurus,
>          I am new to this list to start with RTEMS for my new project.
>    The CPU on proejct has been determined to use BF533(which is a uion in
> BLACKFIN). But not yet
>    determined for RTOS.
>         After I reviewed several RTOS, RTEMS is good enough for the
>    project. But I am wondering if RTEMS supports enough for the CPU, I
also
> konw RTEMS support
>    the Blackfin CPU only in Nov.12th in 2006.  I think it was too new to
> support enough for Blackfin CPU.
>    Because I have cross compile the Hello example two week ago,But still
can
> run succsesfully on the ezkitBF533.
>   I am afraid that it can't suppurt enough for the ASM instruction(which
run
> ok in the VDSP4.5++,
>   but run not OK with the RTEMS(I debug the hello example with the
> SKYEYE,only found:when excute
> "p1.h = hi(flashA_csio);
>  p1.l = lo(flashA_csio) + portA_data_out;
>  r0 = 0x0;
>  w[p1] = r0;
>  ssync;"
> especially " w[p1] = r0;",it said "Watchdog expired. target detached",from
> this I think the RTEMS is support not enough good
> for Blackfin CPU.
>      And our finally product(with RTEMS) should has the function:
> LCD,WIFI,USB,Do you think RTEMS now can meet this function?
>     The above is only my idea.Everyone who has another idea may tell
me,also
> who has test successefully with the "hello,ticker example on the ezkit533"
> aslo can tell me how to correctly set or do.
>     Thanks for your attention.
Fra
> nk
> 人 山 人 海 盛 景,尽 在 梦 幻 西 游
> 劲 爆 150 万 同 时 在 线,众 人 追 捧 梦 幻 西 游
> rtems-users mailing list
> rtems-users at rtems.com
