Can't install user extensions?
Fri Aug 3 15:59:16 UTC 2007
Robert S. Grimes wrote:
> Hi,
> Trying to create user extensions, but get error 5 "too many".  I have
> this defined before confdefs.h
>     #define CONFIGURE_MAXIMUM_USER_EXTENSIONS   10
> I started with 1 or 2, but still no luck
> My code looks like this:
>       rtems_name name_;
>       rtems_id   id_;
>       rtems_extensions_table extTable;
>       extTable.thread_begin   = taskBegin;
>       extTable.thread_create  = taskCreate;
>       extTable.thread_delete  = taskDelete;
>       extTable.thread_exitted = taskExitted;
>       extTable.thread_restart = taskRestart;
>       extTable.thread_start   = taskStart;
>       extTable.thread_switch  = taskSwitch;
>       extTable.fatal          = userFatalError;
>       name_ = rtems_build_name('R', 'M', 'o', 'n');
>       rtems_status_code status = rtems_extension_create(name_,
>     &extTable, &id_);
> The call to rtems_extension_create fails, again with the "too many"
> error.  By the way, this is being called from the user's Init function.
> I step into the rtems call, but quickly get lost
> I see no significant (and relevant) difference between my code and the
> sp07 test program.  What I'm doing seems identical.  A search of the
> Wiki and mailing list archives turned up nothing relevant.  Any ideas?
is the manager configured or do you have the stub?
> As an aside, I can't figure out how the tests are created.  The
> README.configure suggests using --enable-tests, which I did, and "do a
> 'make test'  to build the full test suite', but make complains that
> 'test' is not a valid target.  So I can't report wheter the sp07 test
> program works or not...
> Thanks!
> -Bob
> rtems-users mailing list
> rtems-users at rtems.com
