question about capture component
Robert S. Grimes rsg at alum.mit.edu
Tue Aug 7 18:23:52 UTC 2007
Hi,
Funny, I just started using this today!  It is actually documented on
the Wiki:
    http://www.rtems.org/wiki/index.php/Capture_Engine
I've also started to put together a page on this and some of the other
debugging/monitoring facilities that RTEMS provides here:
http://www.rtems.org/wiki/index.php/DebuggingHints#Optional_Debugging_Tools_Provided_by_RTEMS
For me, I just followed the directions from the first link above,
namely, include these files:
  #include <rtems/monitor.h>
  #include <rtems/capture-cli.h>
and these calls:
  rtems_monitor_init (0);
  rtems_capture_cli_init (0);
in your main init function.  Then, when you run it, you'll get a command
prompt on your primary serial console (I had to hit carriage return once
first).
Enjoy,
-Bob
Yu Chen wrote:
> hi,
>   I  found /rtems-4.7.99.1/cpukit/libmisc/capture is a "RTEMS
> Performance Monitoring and Measurement Framework", but I didn't find
> any testsuit or example to use it.
>   Is capture component is out of date?
>   or the /rtems-4.7.99.1/cpukit/libmisc/monitor can replace capture?
