Stack Checker - Cool!
Robert S. Grimes
rsg at alum.mit.edu
Thu Aug 16 16:47:07 UTC 2007
Figured I should test to see if it actually works! Here's my code:
#ifdef BLOWUP_STACK
void blowup_stack(int numCalls) {
char buffer[256];
sprintf(buffer, "call %d", numCalls);
Logger::Instance().LogMessage(CLCDebug, "StackBlower: call %d,
buffer: [%s]",
numCalls, buffer);
rtems_task_wake_after(25);
blowup_stack(numCalls+1);
#endif // BLOWUP_STACK
Simple infinite recursion - a not so beautiful thing! It simply
allocates a buffer, sprintf's to it, sends an Ethernet broadcast with
the assembled messages, then recurses. Here's the console output:
*** Master Processor - Starting Application Initialization ***
*** From now on, the Ethernet Logger should be the primary output
of ***
*** these sorts of informational messages, with the sole exception
of ***
*** ISR-level messages. The console is hereby handed over to the
RTEMS ***
*** Monitor and Capture
Engine. ***
*** Please report any other messages to rsg at nowhere.com at your
earliest ***
convenience... ***
Monitor ready, press enter to login.
Hit <cr> to access RTEMS Monitor facility...
BLOWN STACK!!! Offending task(0x100F38): id=0x0A010001; name=0x55493120
stack covers range 0x1075C0 - 0x109DC7 (10248 bytes)
Damaged pattern begins at 0x001075C8 and is 128 bytes long
rtems-4.7.99.2(PowerPC/PowerPC 405/virtex) PANIC ERROR 81
system stopped, press RESET
And here are the Ethernet messages:
12:38:14 PM : *** Master Processor, Reporting for Doodie! ***
12:38:21 PM : StackBlower: call 1, buffer: [call 1]
12:38:21 PM : StackBlower: call 2, buffer: [call 2]
<snip>
12:38:27 PM : StackBlower: call 26, buffer: [call 26]
12:38:28 PM : StackBlower: call 27, buffer: [call 27]
Oh, what a beautiful thing! (Of course, I hope I never see that
printout again!!!)
Thanks, Joel!
-Bob
