OT (maybe) RESOLVED - How to create a library of libraries
Robert S. Grimes rsg at alum.mit.edu
Wed Aug 22 12:51:58 UTC 2007
Hi Chris,
That worked like a charm!!!  Thanks, to you, and whoever wrote the
original code!  Here's what I'm now using in my new Makefile, which is
simplified a bit, as I'm only assembling libraries:
  $(LIB): ${SUBLIBS}
      rm -f $@
      rm -rf $(ARCH)/*.o
      for f in $(SUBLIBS); do \
        cd $(ARCH); \
        $(AR) xv ../$$f || exit 1; \
        chmod a-w * ; \
        cd ..; \
      done
      ls $(ARCH)/* > $@-list
      $(AR) rc $@ @$@-list
      rm -f $@-list $(ARCH)/*.o
      $(RANLIB) $@
And now I only need to link in one library, instead of seven (now, and
still counting!) - wicked!
Thanks again,
-Bob
Chris Johns wrote:
> Robert S. Grimes wrote:
>> So I created a new library (in projectroot/libs/uberlib) that has
>> another Makefile.lib-based Makefile, except instead of putting object
>> files into the output library, it puts the other libraries.
> This will not work. The linker does not know the library is a library
> of libraries. The linker will only work with a library of object
> files. You need to *merge* the libraries.
>> Am I missing something?  Or more accurately, what am I missing?
> There is no standard way to do this. It is often hand crafted to suit
> your build system specifics. A nice example is already in RTEMS and
> used to build the librtemscpu.a library. Take a look in:
>  cpukit/wrapup/Makefile.am
> and search for 'librtemscpu.a: $(TMP_LIBS)'. This script code extracts
> the libraries into a directory then creates a new library containing
> all the extracted object files.
> Regards
> Chris
