Linkage order for compiler-generated code?
Thu Aug 23 01:54:06 UTC 2007
Phil Torre wrote:
> We build our powerpc-targeted RTEMS code on either Cygwin or Linux,
> as suits the particular developer.  A while back, I made sure that
> we could obtain a bit-identical image from the same source, regardless
> of build host.  I just went back to revisit that assumption, and found
> that it was false.
Your mileage may vary here. I help chase a similar sort of issue with the
Coldfire for the same gcc version on different versions of Windows. It turned
out MS had change the sort function and this changed the way some registers
where being placed on the stack and this changed the code. Both sort routines
where correct and the generated code was correct.
> Does anyone know what controls the order that the extra functions get
> linked in?
Is it the order of the files linked and therefore depends on the file system ?
It could also be the order of the objects in the library that provides those
functions being linked in.
You might be able to control this with a linker command file, eg try and list
the specific functions in the correct section. I have never done this so do
not know if it is possible.
>  (This is more appropriate to the gcc list, but I can't
> find anything even relevant there.)
You may find binutils is more appropriate, ie ar and ld.
The compiler is free to change the order of these things and still be correct.
People often embed a date and time into systems and this also effects the CRC.
In past system where this sort of thing is important we have written into the
validation procedure exclusion regions and then diff'ed the images. The CRC
was not the compared.
Regards
