RTEMS 4.7.99.2 Available -- PowerPC/virtex feedback
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Aug 10 14:19:47 UTC 2007
Robert S. Grimes wrote:
> gregory.menke at gsfc.nasa.gov wrote:
>> You'll have to apply -msoft-float to more than the RTEMS kernel, newlib
>> (being part of the toolchain) needed to be compiled with it as well.
> Does this mean rebuilding gcc? Or can newlib be built separately?
> I assume I'll need to reconfigure gcc, right? What switch to I add to
> the configure command?
If you are using the RTEMS RPMs or standard configure
command, then you have a lot of multilib variants.
GCC has some differences for 403, 405, and 405fp.
Is the virtex CPU really a 403 like the CPU_CFLAGS indicates?
This is the difference from gcc's viewpoint:
= {{"401", PROCESSOR_PPC403, POWERPC_BASE_MASK | MASK_SOFT_FLOAT},
{"403", PROCESSOR_PPC403,
POWERPC_BASE_MASK | MASK_SOFT_FLOAT | MASK_STRICT_ALIGN},
{"405", PROCESSOR_PPC405,
POWERPC_BASE_MASK | MASK_SOFT_FLOAT | MASK_MULHW | MASK_DLMZB},
{"405fp", PROCESSOR_PPC405,
POWERPC_BASE_MASK | MASK_MULHW | MASK_DLMZB},
{"440", PROCESSOR_PPC440,
{"440fp", PROCESSOR_PPC440,
--joel
> Thanks,
> -Bob
> rtems-users mailing list
> rtems-users at rtems.com
