Periodic timer?
Aaron J. Grier
aaron at frye.com
Wed Aug 22 18:45:01 UTC 2007
On Tue, Aug 21, 2007 at 07:57:25PM -0400, Robert S. Grimes wrote:
> What is the preferred way to implement a periodic timer? My first
> attempt was to use an rtems_timer, calling rtems_timer_fire_after, but
> this only fires once, and I couldn't find an option to cause it to
> repeat automatically.
you can have the timer function set itself to fire again. (:
> I ended up using rtems_rate_monotonic_period instead, even though I
> don't care about missing a deadline here. Still, it seems kind of
> cool to know when I do miss a deadline! So, here is my approach,
> simplified:
> // Use rate monotonic periods
> while (1) {
> status = rtems_rate_monotonic_period(period, perTicks);
> doWork();
> if (status != RTEMS_SUCCESSFUL) {
> reportError("Too slow!");
> Question 1: Is this an appropriate (mis)use of
> rtems_rate_monotonic_period?
that's standard usage.
> Question 2: Let's assume doWork() normally takes perhaps 50% of the
> period to execute. What happens if doWork() it takes too long every
> now and then? Is the timing of subsequent periods maintained, or is
> it reestablished the next time through the loop? I'm guessing the
> latter.
I believe a call to rtems_rate_monotonic_period() re-establishes the
beginning of another period, even if the previous period's deadline has
expired. Joel?
> Question 3: Given my assertion that I don't care too much about late
> deadlines here, is it an overkill compared to this approach?
> // Simple sleep
> while (1) {
> rtems_task_wake_after(perTicks);
> doWork();
the benefit of using rtems_rate_monotonic_period() is that the time of
doWork() is included in the period. with the simple sleep(), the
periodicity will be sleep + doWork.
Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
