Two UARTS
Aitor.Viana.Sanchez at esa.int
Fri Aug 31 14:01:50 UTC 2007
OK,
I already tried with this code.
fp = fopen("/dev/console_b", "r+");
if(fp == NULL)
std::cout << strerror(errno) << std::endl;
fprintf(fp, string);
fflush(fp);
where string is a char* passed as an argument to the routine containing
the fprintf.
The problem is that the fopen routine returns "No such file or directory"
error.
In the RTEMS configuration file this options are specified
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
#define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 2
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
In principle, as far as I read, should work, but it does not. Has anybody
any clue?
Cheers,
Aitor
Sent by: rtems-users-bounces+aitor.viana.sanchez=esa.int at rtems.org
31/08/2007 15:21
To
cc
RTEMS Users <rtems-users at rtems.org>
Subject
Re: Two UARTS
could be using the devices /dev/console and /dev/console_b
Cheers
31/08/2007 15:16
To
cc
Subject
Two UARTS
Hi everyone,
I've got, for sure, and stupid question. I am working with the RTEMS for
LEON architecture. I know that the standard output is connected with the
UART1, but I also have an UART2. I would like, from a user application, to
send some trace information out through the UART2...which the easiest way
to do that?
Cheers,
Aitor
Joel Sherrill <joel.sherrill at oarcorp.com>
30/08/2007 15:39
To
cc
Subject
Re: MacOS Tools
Aitor.Viana.Sanchez at esa.int wrote:
> I tried to install the sparc-rtems-gcc using macports but did not
> work. I don't know whether all the RTEMS related tools listed in the
> macports SVN work properly or not. Does anybody know the status of
> these tools?
I suspect the port files are horribly out of date. For sure, they do not
distinguish between 4.6, 4.7, and 4.8. So that's a bad sign.
Here are the tool versions listed in the arm-rtems-gcc Portfile:
gcc 3.2.3
newlib 1.11.0
gcc-${version}-rtems-20030507a.diff
newlib-${newlibversion}-rtems-20030605.diff
That looks suspiciously like an older 4.6 toolset.
$ /opt/rtems-4.6/bin/arm-rtems-gcc --version
arm-rtems-gcc (GCC) 3.2.3 (OAR Corporation
gcc-3.2.3-20040420/newlib-1.11.0-20030605-4)
So it needs to be updated in various ways.
--joel
> Cheers,
> A..
> *Joel Sherrill <joel.sherrill at oarcorp.com>*
> 29/08/2007 20:39
> To
> cc
> Subject
> MacOS Tools
> Hi,
> I was curious about how to package tools for MacOS and
> went prowling on the web. I knew about BSD ports but didn't
> know about this site which has a lot of RTEMS ones
> http://svn.macports.org/repository/macports/trunk/dports/cross
> Is someone on this list responsible for them? They appear to
> be old since the gcc is 3.2.3 and there is no mention of
> rtems 4.7 or 4.8.
> I am hoping this provides a starting point for someone who
> is interested in providing MacOS hosted RTEMS tools.
> --joel
> rtems-users mailing list
> rtems-users at rtems.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20070831/5ddcce0c/attachment-0001.html>
