Two UARTS
Aitor.Viana.Sanchez at esa.int
Fri Aug 31 14:21:11 UTC 2007
The same behaviour happens also if I change the "/dev/console_b" for
"/dev/console" device in the fopen call.
There is also something strange: If the "r+" option is set, "no such
device" error is raised but if "w+" is set instead, no error is raised but
the fprintf call does not printf anything anyway.
In the RTEMS configuration file the option
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
is set as well.
Aitor
Joel Sherrill <joel.sherrill at oarcorp.com>
Sent by: rtems-users-bounces+aitor.viana.sanchez=esa.int at rtems.org
31/08/2007 16:13
To
cc
RTEMS Users <rtems-users at rtems.org>
Subject
Re: Two UARTS
Aitor.Viana.Sanchez at esa.int wrote:
> OK,
> I already tried with this code.
> fp = fopen("/dev/console_b", "r+");
> if(fp == NULL)
> std::cout << strerror(errno) << std::endl;
> fprintf(fp, string);
> fflush(fp);
> where string is a char* passed as an argument to the routine
> containing the fprintf.
> The problem is that the fopen routine returns "No such file or
> directory" error.
> In the RTEMS configuration file this options are specified
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
> #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 2
> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> In principle, as far as I read, should work, but it does not. Has
> anybody any clue?
Looking at the CVS head, there is no obvious reason in the leon2 device
driver that the /dev/console would work if /dev/console_b doesn't. I
would recommend stepping into console_open() and seeing what happens.
I assume you still have the console device driver configured since they
are in the same driver.
--joel
> Cheers,
> Aitor
> *Aitor.Viana.Sanchez at esa.int*
> 31/08/2007 15:21
> To
> cc
> Subject
> Re: Two UARTS
> could be using the devices /dev/console and /dev/console_b
> Cheers
> 31/08/2007 15:16
> To
> cc
> Subject
> Two UARTS
> Hi everyone,
> I've got, for sure, and stupid question. I am working with the RTEMS
> for LEON architecture. I know that the standard output is connected
> with the UART1, but I also have an UART2. I would like, from a user
> application, to send some trace information out through the
> UART2...which the easiest way to do that?
> Cheers,
> Aitor
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20070831/c11d9352/attachment-0001.html>
