A query regarding old RTEMS source tree
jennifer at oarcorp.com jennifer at oarcorp.com
Mon Dec 10 12:57:24 UTC 2007
The old exception processing is no longer supported.  If your BSP used
the old exception model you will have to convert it to the new exception
model.  If I remember correctly a compiler switch was used to trigger which
exception processing was used.  You may want to look at the other power pc
models for examples.
Jennifer Averett
> Hello,
> I am porting an old (2001) customized BSP  for powerpc in RTEMS4.7.  In
> doing that I noticed that there was a directory named "support" under
> c/src/lib/libbsp/powerpc location which had "new_exception_processing" and
> "old_exception_processing" subdirs. But RTEMS4.7 doesn't have this
> directory. I couldn't find any reference in Changelog about this
> directory. It might have been moved to another place in the source tree
> like c/src/exec has been moved to cpukit or permanently removed. Can
> anyone suggest me how should I deal with this directory while porting that
> old bsp in RTEMS4.7?
> Best Regards,
> Md Sazzadur Rahman
> Graduate Student,
> School of Computer Science,
> University of Oklahoma,
> Norman, Oklahoma, USA
> rtems-users mailing list
> rtems-users at rtems.com
