Looking for BSP for Atmel AT91SAM7X-EK
Kate Feng
feng1 at bnl.gov
Mon Dec 17 14:29:23 UTC 2007
Till Straumann wrote:
>Ralf Corsepius wrote:
>>On Wed, 2007-12-12 at 21:27 -0700, Andrei Chichak wrote:
>>>Thanks Joel,
>>>Are there any docs around dealing with putting together a new BSP? I
>>>have taken a look at the BSP and porting guides but there doesn't
>>>seem to be a section on which configuration files to munge to get the
>>>bootstrap procedure to pick up the new BSP.
>>Well, actually, it's pretty simple.
>>1. cd <src>/c/src/lib/libbsp/<cpu>
>>and copy over the BSP which resembles to your BSP most
>>cp <bsp> <mybsp>
>>2. edit your bsp's files below <mybsp>/
>>[The actual act of porting]
>If I may comment: that would be pretty bad practice.
>A better way would be
> - make parts in <bsp> that are similar enough to what
> 'mybsp' needs a library that supports both, <bsp> and
> <mybsp>. Try to make interfaces generic enough so that
> they could be useful to a yet more similar BSP that
> may be created in the future (but also: try to keep it simple).
> - modify <bsp> so it uses the (new) library
> - let <mybsp> use the library
> - only add new parts that are really specific to <mybsp>
>The myriad of powerpc BSPs are a painful example of
>the result of the 'copy + edit' strategy when creating new
>BSPs. It's maintenance hell.
I somehow agree with what Ralf Corsepius wrote :
> The poor shape the powerpc BSPs are in is a result of lack of RTEMS
> internal APIs and structural defects of the source code (esp. the
> "shared" dirs).
Technically speaking, to reduce maintence effort effectively, one
should start to think about C++ for Object Orient Programming.
Kate
>T.
>>3. cd <src>/c/src
>>../../bootstrap
>>The next configure run should pick up <mybsp> automatically.
>>Ralf
>>_______________________________________________
>>rtems-users mailing list
>>rtems-users at rtems.com
>>http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20071217/9dc51f69/attachment.html>
