Patch for "strict order mutex"
Sun Dec 23 21:47:09 UTC 2007
xi yang wrote:
> This afternoon I got the latest RTEMS from CVS then reviewed my patch
> and find another problems in my patch also in your changes.
> 1)in coremutex.c .
> Documents said :" If a binary semaphore is created with a count of
> zero (0) to indicate that it has been allocated, then the task
> creating the semaphore is considered the current holder of the
> semaphore."
> I missed this term so there is a bug in my patch . But I still find a
> problem(maybe) that
> in coremutex.c if initial_lock == CORE_MUTEX_LOCKED and the mutex is
> inherit or celling
> then we should add the mutex to the thread's lock mutex list . Also if
> the mutex with
> celling priority I think we should improve the Thread_Executing 's
> priority to the celling
> priority (right ?) just like what the
> MACRO(_CORE_mutex_Seize_interrupt_trylock_body) in
> coremutex.inl do (right?) . If you think it is right , I think we
> should add the "check and improve the priority" codes to coremutex.c .
I do not know. I will leave this for Joel to answer.
> 2)in sp36.
> Sp36 is just used to test the strict_order_mutex , I added a return value for
> rtems_semaphore_release directive , which is CORE_MUTEX_RELEASE_NOT_ORDER.
> But this value just appear in code when __STRICT_ORDER_MUTEX__ is defined .
> So I check whether __STRICT_ORDER_MUTEX__ is defied , if not , define
> CORE_MUTEX_RELEASE_NOT_ORDER to a special value , in the begin of sp36,
> test CORE_MUTEX_RELEASE_NOT_ORDER.
Great. Did you also add a test of a semaphore created locked ?
> 3)in cpukit/configure.ac
> You changed it to
> [test x"${ENABLE_STRICT_ORDER_MUTEX}"= x"1"],
> But it should may be
> [test x"${ENABLE_STRICT_ORDER_MUTEX}" = x"1"],
Yes this is the bug I did not see and fix.
> When building RTEMS , I find the "sync" and "gettimeofday"  tow functions
> conflict with declarations in toolchain . (My toolchain is old ?)
Yes. This is life on the bleeding edge of RTEMS and the tools. Thanks to Ralf
all I need to do is issue a yum command to update.
Regards
