CPU table removal comment
Chris Johns
chrisj at rtems.org
Wed Dec 5 22:47:14 UTC 2007
Joel Sherrill wrote:
> Chris .. why don't you go ahead and post your description
> of the core constructor and let the community begin to
> discuss it.
I will.
I will also post something about the examples/net demo work I have done and
the changes to the bsp cfg files. Until then anyone interested can take a look at:
http://www.rtems.org/ftp/pub/rtems/people/chrisj/
> I put the bsp_xxx_hook()'s in exinit because I wanted rid
> of the CPU Table. It worked and didn't require a whole
> lot of additional rework. I had the potential to break
> enough without that.
Sound great.
> As I have mentioned in private emails, I would like the
> BSP framework to gain more initialization responsibility
> and thus reduce code duplication. I really want the BSPs
> to be able to tell the framework (e.g. boot_card right now)
> that I have X bytes of RAM starting at address Y. The BSP
> framework can then split that between the Workspace
> and C Program Heap as appropriate.
> Long term, this lays the groundwork for having the ability
> to have a single heap like some other RTOS's which in
> conjunction with the unlimited object support, will be a
> nice combination. All memory would be in a single pool
> for OS and application usage.
> By centralizing the splitting of memory and C library
> initialization, it would also be easier to disable things
> and deal with errors during initialization.
Excellent news. I had not seen the relationship between the cpu table and the
heap.
> Getting rid of the CPU Table was the beginning of the
> process, not the end.
And I think core constructors can compliment this work by moving control to
the BSP as well as providing more flexibility.
The core constructors change requires updated linkcmd files.
Regards
