Dynamic memory allocation approaches for C++ apps - pros and cons
Chris Johns
chrisj at rtems.org
Sun Dec 9 02:29:06 UTC 2007
Joel Sherrill wrote:
> (2) Much code is terribly optimistic about malloc() and
> doesn't ever worry about it failing. This can result in
> strange situations when you do run out of memory.
I agree. I think the c/src/libchip/ide/ata.c code needs to be reviewed and
changed. It uses malloc and free for block IO requests. The semaphore
create/delete per request could also be looked at.
Regards
