RES: Are there any IDEs for RTEMS?
Jiri Gaisler jiri at gaisler.com
Mon Dec 10 11:18:16 UTC 2007
Gaisler Research provides a Eclipse CDT plugin with support for
the RTEMS SPARC port (erc32, leon2, leon3). The plugin is configured
to use the sparc-rtems-gcc tool-chain and the integrated compile
environment RCC (RTEMS + gcc).
Jiri.
Fabricio de Novaes Kucinskis wrote:
> As far as I know, there is no Eclipse plugin for RTEMS, but I use the CDT (C
> & C++) plugin. It demands some (little) configuration to work with RTEMS,
> but it's very good!
> And if you want to use GDB through Eclipse, try the Zylin plugin
> (http://www.zylin.com/embeddedcdt.html)
> Regards,
> Fabricio.
> -----Mensagem original-----
> De: rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org]Em nome de NOi?
> Enviada em: domingo, 9 de dezembro de 2007 07:54
> Para: rtems
> Assunto: Are there any IDEs for RTEMS?
> Hi all:
>     are there any plugins for eclpse or visual stdio?
> rtems-users mailing list
> rtems-users at rtems.com
