Looking for BSP for Atmel AT91SAM7X-EK
Till Straumann
strauman at slac.stanford.edu
Fri Dec 14 08:33:48 UTC 2007
Ralf Corsepius wrote:
> On Wed, 2007-12-12 at 21:27 -0700, Andrei Chichak wrote:
>> Thanks Joel,
>> Are there any docs around dealing with putting together a new BSP? I
>> have taken a look at the BSP and porting guides but there doesn't
>> seem to be a section on which configuration files to munge to get the
>> bootstrap procedure to pick up the new BSP.
> Well, actually, it's pretty simple.
> 1. cd <src>/c/src/lib/libbsp/<cpu>
> and copy over the BSP which resembles to your BSP most
> cp <bsp> <mybsp>
> 2. edit your bsp's files below <mybsp>/
> [The actual act of porting]
If I may comment: that would be pretty bad practice.
A better way would be
- make parts in <bsp> that are similar enough to what
'mybsp' needs a library that supports both, <bsp> and
<mybsp>. Try to make interfaces generic enough so that
they could be useful to a yet more similar BSP that
may be created in the future (but also: try to keep it simple).
- modify <bsp> so it uses the (new) library
- let <mybsp> use the library
- only add new parts that are really specific to <mybsp>
The myriad of powerpc BSPs are a painful example of
the result of the 'copy + edit' strategy when creating new
BSPs. It's maintenance hell.
T.
> 3. cd <src>/c/src
> ../../bootstrap
> The next configure run should pick up <mybsp> automatically.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
