Behaviour change for double-free'ing a pointer
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Dec 19 20:44:15 UTC 2007
Aaron J. Grier wrote:
> On Wed, Dec 19, 2007 at 10:11:52AM -0600, Joel Sherrill wrote:
>> There is no good answer. I am sure someone will argue that there
>> should be no assert's in the normal runtime. At least people have
>> vehemently argued that before. :-D
> -DNDEBUG doesn't work anymore? (=
This begs a bigger question... should RTEMS assert at all?
Most of the asserts I have analyzed over the past couple of months
cannot occur unless there is a data corruption problem or problem
with the RTEMS internal logic. Those are being marked with
RTEMS_DEBUG conditionals. Otherwise they are untestable
dead code.
Should it be possible for RTEMS provided code to halt at run-time?
--joel
