PR690 (gthread wrappers leak memory)
Thu Feb 1 18:33:51 UTC 2007
Till Straumann wrote:
> Ralf Corsepius wrote:
>> On Wed, 2007-01-31 at 16:55 -0800, Till Straumann wrote:
>>> By accident I stumbled over this.
>>> I believe the fix I submitted a long time ago
>>> is still good. Is it OK to apply it and close PR960?
>> OK with me, if you are able to confirm it works, really solves a problem
>> and nobody objects - I don't have any possibility to test it ;)
>> Ralf
> Using a tool I have to find memory leaks I could confirm
> that the test program attached to 690 does indeed leak
> memory and that my fix plugs the leak (tested on psim
> with 4.7-branch, gcc-4.1.1).
> Also, I have used the patch locally with rtems 4.6.5 on
> a number of VME powerpc systems for months.
Are there any other PRs which have been overlooked like this one?
Do you have the 4.6 branch checked out?  Just for posterity's sake,
I would like to get this PR closed on that branch.  I don't know whether
or not there will be another 4.6 release but it would be better if this
were fixed on the branch.
> FWIW...
> T.
