Can't build CVS rtems-4-7-branch
Tue Feb 6 23:01:25 UTC 2007
Till Straumann wrote:
> Joel Sherrill wrote:
>> I think I have fixed all the message queue compilation error issues
>> in 4.7 and 4.8.  I
>> can compile for sparc/leon2 now anyway.
> Shouldn't we fix that ugly    void*  <-> uint32_t cast (by means
> of a union) ?
The problems I was fixing were from Ralf (correctly) changing the
arguments to the message
queue services in the core and various APIs to size_t for message sizes
and uint32_t for
number of messages.
I didn't see any void * <-> uint32_t casts.  What code are you referring to?
FWIW I do see what I think are new warnings on the mvme2100 but haven't
looked into
those yet.
> T.
>> There is still a warning on the posix message queue code about losing
>> a const.
>> Probably the core message queue insert prototype should take a
>> constant pointer
>> but I haven't checked that yet.
>> --joel
>>> Ralf Corsepius wrote:
>>>> On Mon, 2007-02-05 at 15:49 -0800, Till Straumann wrote:
>>>>> You might want to double-check Ralf's post from
>>>>> over the week-end.
>>>> Yes, it's related to it. I've started to commit changes related to
>>>> declarations, to provoke the bug I am suspecting and plan to commit
>>>> more
>>>> similar changes in near future (probably today).
>>>>> He probably changed the declaration of _CORE_message_queue_Seize
>>>>> but you still pick up an old header that's in your build tree
>>>>> ../../cpukit/../../../mvme2100/lib/include/rtems/score/coremsg.h:
>>>> May-be, may-be I missed something. I thought, I was carefully checking
>>>> not to break something, but ... may-be I did - To be investigated.
>>> It also looks like librtems++ does not compile.  I just committed
>>> changes
>>> to get that to compile but it looks like the librtems++ test needs
>>> tweaking
>>> also.
>>> I will try to compile some more and see if I can fix that.
>>> --joel
>>>> Ralf
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
