Could not run Loopback test routine
Ali Asgar Nasir aliasgar.nasir at patni.com
Wed Feb 7 06:12:44 UTC 2007
Hi,
I am trying to run the network loopback test routine supplied with the
source code of RTEMS. However I could not get the output as expected.
After some debugging I found that the call to accept routine from the
servertask does not return properly and the control goes to a label named
uhoh which is an infinite loop.
I also could not found any calls to the Ethernet driver initialize functions
like rtems_scc1_driver_attach() and other such stuff.
Can anyone help me on this. I doubt I am making a small mistake somewhere.
Regards
Ali
http://www.patni.com
World-Wide Partnerships. World-Class Solutions.
_____________________________________________________________________
This e-mail message may contain proprietary, confidential or legally
privileged information for the sole use of the person or entity to
whom this message was originally addressed. Any review, e-transmission
dissemination or other use of or taking of any action in reliance upon
this information by persons or entities other than the intended
recipient is prohibited. If you have received this e-mail in error
kindly delete  this e-mail from your records. If it appears that this
mail has been forwarded to you without proper authority, please notify
us immediately at netadmin at patni.com and delete this mail.
URL: <http://lists.rtems.org/pipermail/users/attachments/20070207/ff341983/attachment.html>
