Can't build CVS rtems-4-7-branch
Wed Feb 7 17:14:58 UTC 2007
Ignoring everything except Ralf's initial question, I did this
analysis.
These are the "return information" fields available for use in the TCB
we have to choose from:
  uint32_t              count;
  void                 *return_argument;
  void                 *return_argument_1;
  uint32_t              option;
  uint32_t              return_code;
coremsgseize.c does this when a thread blocks:
  executing->Wait.return_argument    = buffer;
  executing->Wait.return_argument_1  = (void *)size;
size is passed in as a size_t so it is certainly bad to put it
in return_argument_1.  We  should have used option or count
and not forced it into return_argument_1.
Which is better to use in your opinion Ralf?  We need to pick
something instead of return_argument_1 for size and use it
consistently. return_argument_1 should only hold pointers.
Do we need to change count or option to another name and
use size_t instead of uint32_t?
As  a future improvement, I can see minimizing the fields in
the Wait_Information structure by having 2-3 instances of
a multitype union (e.g. a union with a void *, uint32_t, and
a size_t).
--joel
>>>>>>> I think I have fixed all the message queue compilation error
>>>>>>> issues in 4.7 and 4.8.  I
>>>>>>> can compile for sparc/leon2 now anyway.
>>>>>> Shouldn't we fix that ugly    void*  <-> uint32_t cast (by means
>>>>>> of a union) ?
>> You didn't get the point: I am having strong doubts this to be necessary
>> and correct.
> I do get the point but I believe you are wrong. I provided an
> analysis of the issue - please reply to that or come up with
> some sort of proof for your suspicion.
> T.
>> I am saying we have a bug somewhere.
>> Ralf
