Can't build CVS rtems-4-7-branch
Till Straumann strauman at slac.stanford.edu
Wed Feb 7 19:04:38 UTC 2007
Joel Sherrill wrote:
> Joel pushes reset and goes back to the start.
> Ralf Corsepius wrote:
>> Have a look at my patch:
>> Here is one:
>> --- cpukit/score/src/coremsgseize.c     6 Feb 2007 03:50:47
>> -0000       1.11
>> +++ cpukit/score/src/coremsgseize.c     6 Feb 2007 17:16:25 -0000
>> @@ -107,7 +107,7 @@
>>      the_message->priority  = the_thread->Wait.count;
>> -    the_message->Contents.size = (uint32_t
>> )the_thread->Wait.return_argument_1;
>> +    the_message->Contents.size = the_thread->Wait.return_size;
>>      _CORE_message_queue_Copy_buffer(
>>        the_thread->Wait.return_argument,
>>        the_message->Contents.buffer,
>> return_argument_1 is a void*, Contents.size is uint32_t => Illegal cast.
> This is the unblocking path from a message queue submit that blocked.
> The blocking
> code is the bottom of coremsgsubmit.c:
>    executing->Wait.id                 = id;
>    executing->Wait.return_argument    = buffer;
>    executing->Wait.return_argument_1  = (void *)size;
> So the above is definitely casting a size_t (not size_t *) into a void *.
> which requires the code Ralf has above to "undo it".  Rather than adding
> return_size, can we switch to using count for message size and use option
> from the Wait information for the message priority?
> I still believe long term, it would be better to have the various
> return_argument
> fields be unions so the space is more effectively used while also
> properly typed.
> But this case clearly forced an integer through a (void *) return
> argument field.
I came to the same conclusion but besides intermediately storing a
size_t in a variable declared as a pointer (which is bad, I agree) I
can't see a bug.
T.
>> Ralf
