configure: error: Missing RTEMS_BSP
Jonathan Kalbfeld jonathan.kalbfeld at gmail.com
Wed Feb 7 19:32:03 UTC 2007
If you want to build the POSIX tests you don't need to specify a BSP.
It should build them as UNIX executables.
On 2/7/07, Amalaye Oyake <amalaye.oyake at jpl.nasa.gov> wrote:
> I am trying to build and run the POSIX tests ... and I am getting a
> configuration errors. How do I set RTEMS_BSP or build POSIX tests?
> ~/RTEMS/rtems-4.6.99.3/testsuites/psxtests$ ./configure
> --enable-rtemsbsp=i386-rtems
> checking for gmake... no
> checking for make... make
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking rtems target cpu... x86_64
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for gawk... gawk
> checking whether make sets $(MAKE)... yes
> checking whether to enable maintainer-specific portions of Makefiles... no
> checking for RTEMS_BSP... configure: error: Missing RTEMS_BSP
> Regards,
> * Amalaye Oyake                                    *
> * Flight Software Applications & Data Product Mgmt */\
> * 818.393.7168 work   818.653.4748 cell            *||
> * Jet Propulsion Laboratory, Pasadena  CA 91109   */||\
> @@@ personal opinions expressed represent only the views of the author @@@
> rtems-users mailing list
> rtems-users at rtems.com
Jonathan Kalbfeld
+1 323 620 6682
