configure: error: Missing RTEMS_BSP
Wed Feb 7 21:33:31 UTC 2007
Jonathan Kalbfeld wrote:
> Oops.  I was mistaken.  He was definitely talking about the POSIX API.
> /me throws paper airplane across the street into Amalaye's building.
> Sorry man :)
I bet all you folks out there make pretty fancy paper airplanes. :)
--joel
> jonathan
> On 2/7/07, Chris Caudle <chris at chriscaudle.org> wrote:
>> On Wed, February 7, 2007 2:32 pm, Jonathan Kalbfeld wrote:
>>> If you want to build the POSIX tests you don't need to specify a BSP.
>>> It should build them as UNIX executables.
>> Are you perhaps confusing the little-used Posix BSP with the tests which
>> exercise the POSIX API mapping of RTEMS?
>> Chris Caudle
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
